BT WEBWISE: What's it about?
- Feedback
- Plusnet Feedback
- BT WEBWISE: What's it about?
10-11-2008 11:25 AM
As a BT Total Broadband customer, you can try an exciting new service called BT Webwise.".
Is this BT trying to get customers to switch?
Re: BT WEBWISE: What's it about?
10-11-2008 11:27 AM
10-11-2008 11:35 AM
http://community.plus.net/forum/index.php/topic,61201.0.html
10-11-2008 11:37 AM
10-11-2008 11:41 AM
In the meantime if you don't wish to connect over the RIN network you can change the DSL login in your modem or router to use the (username)@plusdsl.net realm. Don't forget if you do do this to switch your router off (power-off) and on again to connect.
10-11-2008 12:04 PM
10-11-2008 12:14 PM
Why do you need to switch off the router - all I ever did is to disconnect from RIN, put in the new username and reconnect
Quote from: Peter In the meantime if you don't wish to connect over the RIN network you can change the DSL login in your modem or router to use the (username)@plusdsl.net realm. Don't forget if you do do this to switch your router off (power-off) and on again to connect.
10-11-2008 12:22 PM
A reboot will definitely have the desired effect and it's probaly easier than trying to explain how to disconnect and reconnect on different devices.
(On my router, for example, you need to go to the stats page and click "Drop PPoA" then click "Dial PPoA" to reconnect.)
I also know of at least 1 router that won't permanently commit the change to flash memory without it going through a complete reboot cycle.
10-11-2008 12:28 PM
10-11-2008 12:31 PM
Quote from: jelv Have you got enough capacity if all the RIN users switched back to the Plusnet Centrals?
Yes, there is enough capacity on our centrals. Connection to RIN was as a trial service and yes, we maintain enough capacity to manage users wishing to switch across. In addition there are only a relatively small number of customers on the RIN network.
10-11-2008 12:31 PM
The reason for that is that is the new trial with a limited number of customers being approached
10-11-2008 4:07 PM
@Gel - Sorry you had a surprise this morning. You are one of only around 250 customers who are connecting to the RIN network, as part of the trial we ran between February and September last year. RIN is BT's Retail Network that we were trying out on a trial basis. The RIN trial is unconnected to BT Webwise and it looks as though a configuration error was responsible for the presentation of the Webwise screen. This configuration was put right as soon as we were notified and as we understand it this has been confirmed as the only instance of this occurring. As previously stated, customers using RIN on Plusnet should not see the BT Webwise invitation screen or be able to join the BT Webwise trial.
We can confirm that no further Plusnet customers should be presented with the BT Webwise screen, and that our customers' web traffic will not form any part of the BT Webwise trial.
As I mentioned you can change your connection settings to (username)@plusdsl.net to connect to Plusnet Centrals at any time.
10-11-2008 4:37 PM
10-11-2008 4:49 PM
10-11-2008 4:53 PM
B.
