BT Speedtester
- Feedback
- Plusnet Feedback
- Re: BT Speedtester
- « Previous
- Next »
Re: BT Speedtester
17-02-2011 3:45 PM
Interesting result here.....
haven`t use the bt speedtester for some time.... so this was the first time I used the "new" version...
seemed to "hang" for about 2 or 3 minutes whilst "checking details".... and then gave me this result...
Now this is really good, as I am sitting in my front room with the laptop, wireless connected to the router situated in the back bedroom on the far wall,....
it is even more surprising when you really look at the detail.....
speed achieved....................5470
max achievable speed.......4000
IP profile for line ..................3500
now have a look at the "PlusNet" version ...... My Broadband speedtester....
(no change in laptop position)
Results Image not loaded
Test1 comprises of two tests
1. Best Effort Test: -provides background information.
Download Speed
5470 Kbps
0 Kbps 4000 Kbps
Max Achievable Speed
Download speed achieved during the test was - 5470 Kbps
For your connection, the acceptable range of speedsis 1200-4000 Kbps.
Additional Information:
Your DSL Connection Rate :4248 Kbps(DOWN-STREAM), 443 Kbps(UP-STREAM)
IP Profile for your line is - 3500 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 9.05:42.85:48.11 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
Upload Speed
350 Kbps
0 Kbps 443 Kbps
Date Download Speed Upload Speed
Today 15:36 3207 kbps (401kB/s) 368 kbps (46kB/s)
Today 14:27 3208 kbps (401kB/s) 349 kbps (43.6kB/s)
Today 12:57 3208 kbps (401kB/s) 359 kbps (44.9kB/s)
Re: BT Speedtester
18-02-2011 4:03 PM
Another interesting result.....
but more disappointing than yesterday, at about the same time... (same location for laptop)
should I raise a fault? ? ?
Test1 comprises of Best Effort Test: -provides background information.
Download Speed
2990 Kbps
0 Kbps 4000 Kbps
Download speed achieved during the test was - 2990 Kbps
For your connection, the acceptable range of speeds is 1200-4000 Kbps.
- « Previous
- Next »
