BT Speedtester
jelv
Fixes: 10
BT Speedtester
http://www.plus.net/support/broadband/bbfaults/bt_speed_tester.shtml needs updating as there is a new first page when you go to run it (see attached)
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
31 REPLIES 31
bobpullen
Fixes: 330
Re: BT Speedtester
I'll mention it to the folks who look after the Help & Support content.
Quite odd this one though because AFAIK there's been no official brief from Wholesale to say things are changing. There's also reports of problems running the test if the thread I've just seen over in p.s.customer-feedback is anything to go by.
pierre_pierre
Re: BT Speedtester
and I get another page before that, and I have the latest Java and Firefox on Win7
Then go through to the initial profile page and it starts test 1 and the this error page
bobpullen
Fixes: 330
Re: BT Speedtester
I get the same JAVA error Pierre (Windows 7 x64).
The test was failing for me, although I've just run it again and it seems to have worked.
Perhaps when they fix whatever is broken, they can decide on a consistent spelling for the word 'fiber' too! Wink
Trevor
Re: BT Speedtester
BT Speedtester worked for me too this morning - first time in over a month! And yes, I too got the 'no Java' warning briefly before the Home page then came up as normal. I think they have a bug and need to wait a bit longer before concluding that Java is not installed/enabled.
And it would be nice for us Mac users if they changed 'PC' to 'computer' too, but that would be expecting too much.
bobpullen
Fixes: 330
Re: BT Speedtester
I've emailed the developers to try and find out what's going on...
gswindale
Re: BT Speedtester
Quote from: Trevor
Why?  Is a Mac not a Personal Computer then?
pierre_pierre
Re: BT Speedtester
and also a linux one, what is that but a PC
shutter
Fixes: 67
Re: BT Speedtester
I always thought a MAC was a waterproof coat (WPC!) and Linux was a posh version of LINO  (a waterproof floor covering )  Roll_eyes
pierre_pierre
Re: BT Speedtester
And Micro soft has holes all over it
linux
Re: BT Speedtester
Quote from: Bob
Is there any update on this?
I haven't been able to complete speedtester.bt.com for a week now.
Luzern
Fixes: 9
Re: BT Speedtester
http://speedtester.bt.com has worked fine for me just now.
linux
Re: BT Speedtester
Alas I still get this:
Test Error
The Performance Tester is currently unable to run a speed test for your broadband connection. Please try again shortly, however if this problem persists, raise the issue with your service provider.
It has been like that since BT changed their speedtester page format on 5th February.
The words "raise the issue with your service provider" suggest this is something for Plusnet to address.
Steve
Seasoned Pro
Re: BT Speedtester
Strange, Works fine for me.
If life gives you lemons, make lemonade.
linux
Re: BT Speedtester
Maybe the speedtester is run on the local exchange, in which case the problem might be specific to this area. Does anybody know how the speedtester works?
What I do know is that my last successful test was on 5th February at 12:47, before BT changed their speedtester page format from one page to two pages. It hasn't worked since, on any day or at any time of day.
Perhaps I should raise a ticket.
