Aw Shucks!!!!
collieocoll
Aw Shucks!!!!
Speeds dropped again!!! but moving February so dont require any assistance. Cool
I am certain it aint my problem anyway, and if it is I will take it with me. Roll_eyes
I was feeling rather pleased for a while there!!.  Shocked
Xmas Day: Speed Test Today... 927kbps just wanted to say at least it's consistent if nothing else although its still rubbish. Roll_eyes
Boxing Day Speed Test...... 873Kbps another week or two and I may be back down to 164Kbps WoW!!! how happy I am Sad
3 REPLIES 3
Chris
Legend
Fixes: 169
Re: Aw Shucks!!!!
Everything seems stable at 1000 for your line. If I'm honest, I wouldn't expect much more from your line. If you check in a line checker for a speed estimate, they range from 0.5Mb to 1Mb due to the distance you are from the exchange.
Mand
Re: Aw Shucks!!!!
Your IP profile dropped to 1000 on 23/12/09. What speed are you sync'ing at now?
jelv
Fixes: 10
Re: Aw Shucks!!!!
If you put your attenuation in to http://www.kitz.co.uk/adsl/max_speed_calc.php it will tell you the sort of speed you can expect.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
