Att Adam Walker - Useage
- Feedback
- Plusnet Feedback
- Re: Att Adam Walker - Useage
- « Previous
- 1
- 2
- Next »
30-03-2011 11:45 AM
yes Adam wireless is on WPA...................Thanks..............Roger
30-03-2011 12:31 PM
If all your PCs are Windows you can use NetWorX to record your usage. You can set the peak and off-peak times and it will record data for each. It also has the stats on an hour by hour basis. Best of all it communicates across your LAN and will show the total usage. What it won't show is incoming data hitting your router and not being forwarded to a PC.
30-03-2011 7:49 PM
Ok Jelv...................Yes all windows 7 here, so will look at the info, thanks...............Roger
31-03-2011 10:13 AM
31-03-2011 10:33 AM
Different purpose I'd suggest. NetWorX is brilliant for checking the total traffic and identifying when traffic is occurring. If you see traffic in NetWorX when you think there should be none, then is the time to step in with Wireshark to identify what it is.
Edit: It was a post from Bob P. that first put me on to NetWorX.
Edit 2: ... and NetWorX beats seven bells out of tbbMeter which is a crock of ****!
31-03-2011 10:41 AM
- « Previous
- 1
- 2
- Next »
