Am I asking too much?
Anotherone
Champion
Fixes: 21
Re: Am I asking too much?
Sorry I made a typo in my previous post, had a comma in the last thing instead of the dot (now corrected).
What do you get if you put 192.168.1.254 into the address bar of your browser?
Minivanman
Legend
Same result, somebody up there does not like me or my computer!
Not to worry anyway. It might sort itself out and if not I'll ask for a refund at the end of this month - other than that, wait until the fibre is connected.
Thanks for your time, it was much appreciated. Wink
Truth is like a threshing machine; tender sensibilities must keep out of the way.
Herman Melville
Anotherone
Champion
Fixes: 21
Don't do that - you've got a problem there and this is precisely what the Community is for, to try and help you resolve it - with Plusnet's intervention where needed.
So if 192.168.1.254 does nothing it must give an error message I guess. I think what you had better try next is a factory reset of the modem/router. There's a small pin hole next to the power button on the back it. Use a straightened out paper-clip or similar to press and hold the internal button for  just over 8 seconds until all the lights on the router flash as it goes into reset.
Minivanman
Legend
Yes, just that error message.
Will try the reset as you suggest. Smiley
Herman Melville
Anotherone
Champion
Fixes: 21
OK, I have got to go out, but will be back later. Someone else may reply if there is obvious help to be given.
Minivanman
Legend
Always worth a try doing that I guess. Managed it OK and it reset itself - needed to log back in of course and it took some time go back on line but with no change. Sad
Herman Melville
Caerefail
Can you now log into the router using 192.168.1.254 as requested by Anotherone? You'll need your router password.
