Acount cock up again
- Feedback
- Plusnet Feedback
- Re: Acount cock up again
20-05-2010 2:38 PM
"Before we can investigate a fault, as per the connection logs I've included above since last Thursday you seem to have disconnected from roughly 1.55AM up until any time between 10AM and midnight. Before we do anything else can we just check if this is something you may be instigating by powering off your equipment?
We are of course bearing in mind that what you said about the street light but the times of the disconnections would not seem to match up with when this would be powering up or down."
If you could return the first of the two tickets to us with the relevant answer we'll be able to pick this up for you.
20-05-2010 2:42 PM
20-05-2010 2:46 PM
21-05-2010 1:47 AM
21-05-2010 3:46 PM
14-06-2010 2:21 PM
This does seem to be true as when there has been a drop and I use wireless its hard to connect as there is another station on close by. When there is no drop it connect with no problem.
The fixed profile would be ok if it was the normal 7765 I have sen the figures which show it has connect at this rate for over 6 months and the drops havent effect the speed before now but even connecting at 7765 my Plusnet profile never get above 6500.
I dont see it takes over a month to sort something out
14-06-2010 2:29 PM
It looks like you synced below 7000 a couple of weeks ago and that's when the banded profile was applied (there's also sync rates as low as 3000-odd reported). I suspect the fluctuations are down to the disconnections showing, which look from the times that the router is being turned off when not in use rather than left on all the time, is this the case? If so I'd recommend leaving it on for a week or so to see how it behaves, if it syncs at the top end of the banded profile for a few days solid we'll be able to request that this is removed for you.
14-06-2010 2:37 PM
Leaving it on doesnt have any effect we have tried that it just stay connect at 6656 so it doesnt make any difference to the profile its impossible to connect at a higher speed it wont let you.
Bt connected when they were on site and they got the same results I have turned the router off at night for years and its never had any effect
14-06-2010 2:44 PM
14-06-2010 11:07 PM
15-06-2010 9:23 AM
It's very likely that the banded profile has been applied because of the resyncs, and it's because you turn the router off every night that we can't request for the banding to be removed.
We can remove the banding if you sync at the top of the profile for 72 hours. As you're rebooting every evening and your sync speeds are lower when you power up in the morning, this will not happen as things are.
If you can keep the service synced at 6656kb/s for 72 hours we'll be able to get the banding removed and then be able to push for the 9Mb service.
I suspect the reason things are no longer working as they were under ADSL is simply because of the change up to ADSL2+.
19-06-2010 11:19 PM
I note my upload has dropped as it used to be 968 the stats are
Connection Status Connected
Us Rate (Kbps) 864
Ds Rate (Kbps) 6656
US Margin 10
DS Margin 2
Trained Modulation GDMT
LOS Errors 0
DS Line Attenuation 46
US Line Attenuation 28
Peak Cell Rate 2037 cells per sec
CRC Rx Fast 0
CRC Tx Fast 0
CRC Rx Interleaved 1726
CRC Tx Interleaved 7
Path Mode Interleaved
DSL Statistics
Near End F4 Loop Back Count 0
Near End F5 Loop Back Count 0
21-06-2010 10:44 AM
Unfortunately it looks like there's still occasional drops happening - I'm not sure if the sync rate has held through these however the drops will be enough for BT to refuse to remove the banded profile.
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image1277113233355.png" />
I'd be happy to get a fault raised but the connection isn't incredibly intermittent as you can see from the above - let me know how you'd like to push this forward and I'll get on it for you.
21-06-2010 2:45 PM
I am stuck though its still connecting a gdmt if I try and get adsl2+ and it doesnt work again then it will connect at 3 meg and I am back to square one. I am paying for adsl2+ and would expect it to work with that at the same speed not half the speed. Its this issue which seems to be the problem as if its not setup right
01-07-2010 2:56 PM
Uptime: 4 days, 3:07:27
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 609 / 6,655
Output Power (Up/Down) [dBm]: 12.0 / 20.5
Line Attenuation (Up/Down) [dB]: 25.5 / 47.0
SN Margin (Up/Down) [dB]: 7.0 / 6.5
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Framing (Local/Remote): 11 / 0
Loss of Signal (Local/Remote): 1 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 1 / 0
FEC Errors (Up/Down): 3,036 / 514,279
CRC Errors (Up/Down): 3,036 / 883
HEC Errors (Up/Down): 172,284 / 766
Its been up over 4 days so it should now be possible to get the profile changed but no one is answering the ticket. I assume I will then have to reboot the router to hopefully get a higher speed like the 8 meg I was getting before.
The up speed on the new router is a lot lower as it was 928 on the old one and only 609 on the new one supplied by Plus net
