A way to avoid waiting for technical support
Discobolus
Would it be possible for Plusnet's technical help-line to ask people to key in a phone number so I could be called back when the help-desk is less busy, rather than me waiting in a queue of unknown length unproductively?
10 REPLIES 10
shutter
Fixes: 67
Re: A way to avoid waiting for technical support
@Discobolus  Highly unlikely....just over 10 years ago.....  I suggested that Plusnet put in the "normal" phone system, used by many companies, that have a "help line"... that says  " Your turn is number XXX" or whatever, so you know that you are, "probably moving up the queue.. instead of suspecting you are being by-passed.. ( which in plusnets system is probably more true )
https://community.plus.net/t5/Plusnet-Feedback/Suggestion-employ-more-staff-to-answer-tickets-and-ph...
If you want "Tech help" then your best bet is to post a question on the "Tech board"...
( tech help is not limited to computers or plusnet... whatever you need help with.. lawnmower   motor bike.. camera  video.. phone... etc  ask and ye shall  receive !
Fixes: 1,495
Moderators Note
This topic has been moved from Chat to Feedback.
198kHz
Fixes: 42
Good idea, but don't hold your breath.
Remember Plusnet's motto - Rome wasn't built in a year.
BT technician (Retired)
Discobolus
I have just found an app called weq4u which could solve the problem. It appeared on Dragons' Den
shutter
Fixes: 67
@Discobolus   how much per minute, do they charge you for the privilege ?
shutter
Fixes: 67
Wrong......  It has always been   "Give us time, and we`ll get there"..... for the past 10 yearss or more..... Undecided
Discobolus
There is no charge. On 0800 numbers you are saving 30 per minute
shutter
Fixes: 67
@Discobolus   Excellent !
Mustrum
Fixes: 81
@Discobolus  How can you save 30p a minute on 0800 calls, they are free??!!
Discobolus
Sorry. Some 08 numbers are not free, but I had a senior moment
