Broadband Speed Faults: How to diagnose?
One of the more common questions that we are asked by our customers is “Why is my Broadband slow?” Which in itself is, of course, a perfectly reasonable question. Unfortunately, finding the answer isn’t always quite as easy! We have customers on fixed rate products and max products and the diagnosis on both is quite different. This is predominantly owing to the distinct lack of useful diagnostics available for us on the fixed rate products, but fortunately, on the max (upto 8Mbps) services, there are considerably more diagnostic tools available that help us to diagnose speed issues, as well as tools available for the customer. I’ll be focusing on this product in this posting as at least two thirds of our customers are on the upto 8Mbps product with us. So where do we begin? I think it’s a sensible starting point to set out clear expectations when dealing with speed issues. The first and most fundamental point is that upto 8Mbps means just that. It is not guaranteed. Broadband is extremely dependent on your distance from your local telephone exchange. This is true for signal issues and in extreme cases may result in receiving a Broadband service impossible. Maximum obtainable speeds are dependent on this also. The further you are from the exchange, the poorer quality a Broadband signal you will be able to receive from said exchange. The better the quality of signal, the greater will be the maximum expected throughput speeds, although this also depends on how “busy” your local exchange is, but that’s another issue we can delve into later. One of the most useful tools available to our customers is the BT Speedtester, which gives a reasonable amount of information about the limitations applied to the Broadband connection from a speed perspective. Please note, if you have a broadband speed fault you will need to complete two tests - once the first has completed please click 'further diagnostics' and fill in the details requested before completing the second test. If this is not completed our faults team will not have access to the results. The speed tester is still somewhat in its infancy so can be a little unreliable at busy times of the day. Here’s an example of a result from the Speedtester. BT Speed Test So, as you can see, you are presented with four main pieces of information. Your upstream and downstream synchronisation speeds (this is the speed at which your modem or router is connecting with the BT Exchange), your IP Profile and your actual throughput speed as recorded by the test. For the majority of speed faults, the upstream synchronisation speed can practically be ignored, unless it reports speeds significantly below 448Kbps. The IP Profile is the speed at which BT have restricted your connection to, as they believe that this is the fastest speed that you can receive whilst also receiving a stable connection. The IP Profile is the maximum speed that you will be able to get in a speed test. The downstream synchronisation speed is extremely important. This is the speed at which BT use to calculate your IP Profile. We have a table on our website which shows you’re the relevant synchronisation speeds versus the appropriate IP Profile speeds, which you can find here. You can also see your current profiled speed on our network, which is designed to mirror BTs IP Profile and is updated twice a day. See this here. Unfortunately the IP Profile is not updated on a real time basis. BT take your lowest downstream synchronisation speed (hence the importance of this as I mentioned earlier) over a three day period and then assign the appropriate IP Profile. Here’s where the problems can occur. Downstream line synchronisation can and does fluctuate. There are various factors that can cause line synchronisation to drop and fluctuate. Most commonly these factors can relate to faulty filtering, a suspect modem or router or poor internal wiring. The best setup for any Broadband connection is always to have your modem or router connected into a filter and then for your filter to be connected to your master socket, which is normally the first socket into your house from your road. It is also imperative that every used phone socket in your house has a filter attached, as failure to do this can cause interference between the analogue (normal voice phone) and digital (Broadband) signals. There are also additional factors that can come into play such as poor weather, exchange and line related problems and even things like street lights, central heating and Christmas lights! If your modem or router does drop synchronisation and it regains synchronisation at a lower level, then BT will change your IP Profile speed to reflect this change in reported synchronisation speed within 75 minutes. In extreme cases, this can cause the IP Profile to be set as low as 135Kbps when a resynchronisation event equal to or lower than 160Kbps happens. This does happen to the best of us, including myself, who lives on the same street as his exchange! BT do have in place something they refer to as “Blip Logic”, which is supposed to mean that they will only force a change in profile speed should there be two resynchronisation events lower than the current profiled speed. Unfortunately, this does not always seem to be the case. So, as you can imagine, it is always fundamentally important to ensure that you setup ensures the highest level of signal, by connecting to your master socket (also known as the NTE5) as I outlined earlier. This will result in any potential resynchronisation events being less likely, thus increasing the chances of maintaining a sustained speed at the highest possible level. One of the other factors when it comes down to diagnosing Broadband speed problems is a further connection attribute of the noise margin. Because with Max, BT push the limits of your connection as far as it can go, they will try to attain the highest synchronisation speed with a target noise margin of 6dB. For the majoirty of lines, this will work absolutely fine, especially for those closer to the BT Exchange. However, some lines, especially the longers ones, will experience more "noise". This can be caused by a number of factors on the line, be it poor quality telephone wiring (external), street lighting, transmitters, interference from electronic devices (pylons) and so on. BT will then assign a higher noise margin to the Broadband connection. For every 3dB increase in noise margin, this will result in approximately an 800Kbps reduction in synchronisation speed. Also, this is often one of BTs first measures when trying to fix an intermittent fault. So if we raise a fault to BT for an intermittent connection, they will often raise the target noise margin by 3dB to increase stability on the line at the detriment of speed. So this is also another thing to consider when trying to work out what kinds of speeds you *could* be receiving. So, obviously so far I’ve covered what our customers are able to do and see and the suggested actions and precautions that can be made to cope with the perceived flaws of the service and what information is available to them. We also have our own diagnostic tools available to help to troubleshoot this kind of problems and give a more detailed level of information to help our customers understand the cause of the problems that they experience. In the next part of this posting, I’d like to give you an insight into the systems that we use and the information that we gain from these. We predominantly use systems called “Actuate” and “Woosh”. I’ll start by showing you a standard report from Actuate and the information that we can see from this. Actuate Screenshot The main points of interest that I would usually take from these reports are generally the current profile, the synchronisation rate and the dates and times of resynchronisation rates. From these we are able to easily point at the relevant resynchronisation events and show a customer at exactly when their modem or router suffered a blip and the speed at which the resynchronisation occurred. What is also useful is when there are a large number of “blips” which would often point towards an issue with internal wiring or poor hardware, which means that we are then able to suggest various troubleshooting ideas to our customers. What is also of interest is the interleaving state. Interleaving is a function on the max product that increases the stability on a line, but increases the latency of a connection, which is generally of interest to our customers that enjoy online gaming. This allows us to see if BT have removed interleaving from a line once we have raised an order for them to do so. The other main diagnostic tool that we use is one called “Woosh”, which is essentially a suite of various different tests. The ones I would predominantly use are the “DSL Status Check” and a “One Shot Check”. A lot of the information is repeated, but various tests have their own uses. Here’s a DSL Status Check: DSL Check From my point of view, I tend to use this check to show the current synchronisation speed when checking against the last report resynchronisation event as reported in Actuate. This is useful as we can then inform the customer of what speeds they should expect to receive should this level of synchronisation be maintained for a period of 3 days or more. The One Shot Check is by far a more conclusive all-round test (no screenshots this time I’m afraid as it contains a level of sensitive information), which can be used to diagnose intermittent connection issues, as well as having a use when looking into speed related faults. Whilst it does generally give similar information to that of the DSL Status Check, it does also show how long the current connection has been maintained for, which coupled with our RADIUS (authentication) server allows us to see the length of connection and the current synchronisation speed. It also shows us the number of reconnections in a given time frame. An intermittent connection is likely to have a few low resynchronisation events, thus causing the IP Profile speed to be low. As such we can suggest internal wiring and hardware checks, which will hopefully result in increased stability and as such, an increase in speed. Unfortunately, the one thing that we’re not able to gain a massive amount of information on is exchange contention. Each exchange has a finite amount of bandwidth which Broadband users are able to use simultaneously. For busy exchanges there can be a noticeable slow down during peak times of the day. Whilst we are given a RAG (Red, Amber, Green) report for all of BTs exchanges, this is merely a guideline and not a definitive answer. Our systems of traffic management also need to be considered. Whilst these usually would not impact pure browsing speeds. However, on our Broadband Your Way product line, where our customers have requested a fixed usage amount (as opposed to Pay As You Go), speeds are restricted to 128Kbps. There are also potential speed restrictions on legacy Broadband Plus and Premier products, which can result in speeds being restricted should the usage allocations be exceeded. This should be considered when looking into slow speed results from both our and the customers end. Well, that’s pretty much all I could possibly ever write on this subject, but should there be any further developments on the Broadband services that we provide, I shall endeavour to update further! For an even more definitive guide to the Broadband Max service then please do read the guide on our portal.
62 Comments
62 Comments
bobpullen1
@taz999 your IP profile is restricting your throughout speed, almost certainly the result of the intermittent connectivity problems you've been having. If you post your support ticket reference here then I can take a look and see if there's anything I can do to help?
Bohdan
Very interesting reading indeed,Talk Talk provided me some basic diagnostic software including the ability to change the IP address,therefore havent never had the need to call an engineer out,brill
Woodsider1
Like many others (see Plusnet and other forum postings), I am now getting about 100kbps. About 200k this morning; nearer 50k last night. Why do we all have to raise a ticket? This is clearly not an individual issue.
bobpullen1
@Woodsider sorry to hear you're having problems. Whilst it might not appear to be an 'individual issue', the reason behind your problems will be something specific to *your* line and the environment in which it operates. In order to establish the cause for the speed reduction we need to look specifically at your set of circumstances. The best way for us to do this is for you to raise a fault ticket on your account - http://faults.plus.net
Woodsider1
My ticket is active. But there appears to be a more serious issue. Problems have been going on long enough now that I can say the following. (Bear in mind that I live in a rural area with little business handled by my local exchange.) 1. When I lose a DSL signal, it often happens on the hour or the half hour. As such, it appears to be a system matter, not accident. 2. During school terms, the signal often goes dead at 16.30 (+- 30mins), and sometimes at 09.00, and frequently overnight. I suppose this relates to boosts in load. 3. During school holidays, speeds are generally slower. I suppose this relates to load. 4. Previous advice from PlusNet was to switch the router off/on if the signal died. (I now understand that this actually lowers the speed I will get, which is not what I want atall.) Your advice piece above, and response to my ticket, help me obtain symptomatic relief (avoiding having BT's system lower my speed), which is, as you say, specific to my line. I am wanting a better understanding of the root cause of the problem, which is why the DSL signal gets cut (hundreds of times in the last 12 months, with a frequency that reached several times each day just before the start of the school summer holidays). Then I will know whether to persist with what, for £20 per month, has been an appalling service. In view of other forum contributions it is extremely difficult to believe that this matter is line specific. If it is a matter of BT provision, it is one that should be of PlusNet's concern, rather than cause me a lot of my time.
Woodsider1
Additional clarification. When I say the DSL is dead, I mean that the router still shows a DSL light indicating connection, but there is no internet (as was the case this morning). Sorry if my terminology has not been correct.
bobpullen1
@Woodsider, I'm going to add some further detail to your support ticket shortly, however to address the points you've raised here: 1. Just to clarify, it's your PPP session that is being lost by the sounds of things and *not* your DSL signal (DSL signal is the connection to the exchange). Having said that, the signal *is* being dropped quite frequently as a result of you turning your equipment on/off - whether it's overnight, or to fix things when you lose connectivity, it is playing havoc with the IP profile of your line which over the last fortnight has varied from 135kbps right up to 3000kbps. 2. Over the last fortnight the PPP session has been dropped at the following times: 14:00 16/Aug/2010 21:08 15/Aug/2010 21:45 14/Aug/2010 21:15 12/Aug/2010 09:09 10/Aug/2010 09:02 10/Aug/2010 09:01 10/Aug/2010 07:55 10/Aug/2010 21:50 09/Aug/2010 08:29 09/Aug/2010 02:45 09/Aug/2010 22:16 07/Aug/2010 08:17 07/Aug/2010 21:05 06/Aug/2010 08:53 05/Aug/2010 22:17 04/Aug/2010 21:05 04/Aug/2010 09:40 04/Aug/2010 08:15 04/Aug/2010 22:58 03/Aug/2010 22:46 02/Aug/2010 12:00 01/Aug/2010 3. Quite possibly, although with the fluctuations in your IP profile, I'd be very surprised if you were to notice subtle performance differences due to exchange/network congestion. 4. This kind of relates to the response I've given for the first question. You'd be much better off accessing the router console and manually reconnecting from there instead of rebooting the router. Doing things this way doesn't drop the DSL signal and therefore shouldn't affect your IP Profile (although you'd need to stop turnign things off at night). I'll go into more detail on your support ticket however I'm inclined to agree with what my colleagues have advised at this point which is to try another modem/router (can you borrow one off somebody?)to rule out a hardware fault/misconfiguration. It seems that for one reason or another, your router is not always re-establishing a PPP session when you're disconnected. Would be helpful to know what router it is you're using?
Woodsider1
My router is "BT Voyager 2100" supplied by PlusNet. Some of my response to the above has been included in a lengthy addition to my ticket. Of more general interest is that I have apparently been losing internet access while not (according to the list above) losing my PPP session. (And the PPP session sometimes does not close even when my router has been left switched off.) Also of more general interest is that the data you have supplied confirm that such losses of internet happen on the hour. There is nothing in this house that switches at these hours. Further, the question of which hour is one that changes according to whether it is school term, though there is nobody of school age within about 500m of this rural outpost. No idea what can be done with that information.
jojopillo
@Woodsider It seems that your connection has become a lot more stable since those last results, but if you are still experiencing difficulties then I would maybe try a different router and if that doesn't help then visit faults.plus.net for some further help.
woodsider
Back to topic! ... Concerning the importance of filtering. Above, we read "... your filter to be connected to your master socket, which is normally the first socket into your house from your road. It is also imperative that every used phone socket in your house has a filter attached ...". It transpires that much of the noise on my line (and most of its variability) comes from my only, and unused, extension. So, adding a filter only between used extension sockets and the attached equipment, as James suggest, is not sufficient. The logical answer appears to be to disconnect all extension lines from the back of the plate (which has the master socket) and then reconnect them from a branch off the phone's line from the filter, but I haven't tried that yet.
woodsider
Bob Pullen (12 Aug.) is right. I (14th) was wrong. While the end results are just a few apparent problems (speed, losing internet, ...), the circumstances are individual. It's not that the list of possible issues is much longer than I knew of. It's rather that many issues are negligible or even dormant when they occur alone. (Who cares if internet can't autoconnect after dropping, if it never drops?) So, by the time you are spurred to action you probably have several issues, and the number of possibilities in your circumstance is given by all the possible permutations. If you are just starting to work on a broadband problem, look out for several problems not just one.
woodsider
But ... there are exceptions. Because problems are assumed to be individual, those that are not can be particularly infuriating, and you may never find out whether they have actually been solved. One possible wider problem is congestion within Plusnet's realm. If you raise a ticket, Faults may well respond after the congestion has cleared, and set you on a wild goose chase of checking router, telephone wiring, other home gadgets, ... which is difficult to object to, even if you are sure it's pointless. Then there are BT problems. Even when several of us with different ISPs on the same exchange lost internet access, BT's procedure was not to look at the exchange until engineers had checked individual lines. That may be why we all waited over 48hours before BT personnel admitted to an exchange problem. Even then the exchange checker was Green ("no problem"), and afterwards there was no feedback via Plusnet to say what had been done.
