zyxel ex3301-t0
discoverytdi
zyxel ex3301-t0
Hi all after my brief journey with Quickline (their [-Censored-] by the way) they never picked up the zyxel ex330 told me I could keep it so was thinking could I put it to some use so tried it in place of the original PN hub 2 but would not connect, used the right username and password and connection type so what am I missing anyone
Peter
Moderator's note by Mike (Mav): Avoidance of swear filter edited as per Forum rules.
12 REPLIES 12
Fixes: 585
Re: zyxel ex3301-t0
What Plusnet product do you have ?
discoverytdi
Re: zyxel ex3301-t0
Hub 2
RobPN
Fixes: 15
Re: zyxel ex3301-t0
Yes we know that - you mentioned it in your OP.
Fixes: 585
Re: zyxel ex3301-t0
I meant what broadband product do you have Fibre (SoGEA) or Full fibre ?
discoverytdi
Re: zyxel ex3301-t0
Full fibre 500
Fixes: 585
Re: zyxel ex3301-t0
Thanks.
Your WAN connection should be set to PPPoE , username is <youraccount>@plusdsl.net , password is the one you use to access the member centre (https://www.plus.net/member-centre/login)
Make sure VLAN ID is disabled or set to 0
If you still cant get it to work then post the WAN Interface screens with your settings and we'll check them
discoverytdi
Re: zyxel ex3301-t0
They are, will have to set up the zyxel tomorrow
discoverytdi
Re: zyxel ex3301-t0
WAN Interface screen, I think
Fixes: 585
Re: zyxel ex3301-t0
I'd try changing the IPv4/IPV6 mode to IPV4 only, Plusnet do not currently support IPV6.
I assume you do actually have the username field set to <youraccountname>@plusdsl.net and that you've just redacted it for the post ?
If that doesnt help then try looking at the system log, probably category WAN ( or maybe PPPoE) for a clue as to whats happening. If you need help analysing it , then export it and post it here
discoverytdi
Re: zyxel ex3301-t0
Changed it to IPv4 no change going to admit defeat perhaps it's locked like some phones thanks for your help
Fixes: 118
Re: zyxel ex3301-t0
@discoverytdi
Have you tried a factory reset?
Fixes: 585
Re: zyxel ex3301-t0
@discoverytdi if its allowing you to change the WAN parameters , particularly the username/password , then its unlikely its locked.
