Wifi Strength in Son's Bedroom
w0036471
We have FTTP with a Hub Two router. The router is located next to the point where the fibre enters the property, at the front of the house in the lounge. My 13yo son has just let me know he's upgraded his mobile data package because he doesn't get strong enough Wifi in his room (which is diametrically opposite from the router). I've read 1,001 threads on this forum on this issue, but they're all in complete jargon and I'm still none the wiser as to what I need to do to boost the signal to his room. Running miles of Ethernet isn't really a practical solution, and we rent privately so can't make any physical changes. Our house is an ex-forces brick-built house, built in the late 50s/early 60s, so has pretty robust walls, and I have no idea what the wiring situation is. To add to this, whatever solution we use needs him to still be able to connect his phone to the Chromecast in his telly. Can someone explain to me, like I'm a 5yo idiot, what I need to buy from where, and how to install it please?
23 REPLIES 23
Fixes: 480
Re: Wifi Strength in Son's Bedroom
@w0036471
Options: https://community.plus.net/t5/Tech-Help-Software-Hardware-etc/Distributing-Data-around-Larger-Proper...
There's no straight answer on which will suit your budget and property best.
w0036471
Yeah, that's precisely the jargon-filled guff I was asking for help with translating.
Fixes: 387
@w0036471 Insulting people who try to help isn't a good start.
When he says he 'doesn't get strong enough Wi-Fi' exactly what does he mean, and what is he doing - general browsing/gaming/w.h.y.?
w0036471
He is playing games/watching videos on his phone. The Wifi signal keeps dropping out entirely and pushing him onto his phone's 4G connection.
Fixes: 387
OK. So how big is the house/what is the rough distance between the lounge and his bedroom?
w0036471
So, the house is about 8m wide and 6m deep, so his room is probably 7m or so from the router through a couple of thick walls including the chimney breast and stairwell.
Fixes: 387
@w0036471 wrote:from the router through a couple of thick walls including the chimney breast and stairwell.
So, this is an old house? I'm no networking expert, but maybe use wireless extenders or powerline adapters?
Fixes: 118
@w0036471
PowerLine Adapters are probably the best idea without running ethernet cable.
If you go down this line make sure you get ones powerful enough for your FTTP speed. Others on the Forum might suggest suitable models for you to consider.
w0036471
Yeah, it's a late 1950s ex-RAF married quarters red brick house. I've tried looking on Amazon for wireless extenders but it's so full of unverified knock-offs now it's hard to tell what's a worthwhile product and what isn't, as well as what would actually work with the PlusNet Hub. I kinda hoped PlusNet would have recommendations of products.
Fixes: 387
So, it is brick-built, not some 19th-century castle? I suggest you explore the powerline option, but as said above, I am not a networking expert.
@MisterW  / @Townman  any ideas, or suggestions?
Fixes: 585
Whilst I agree with the powerline suggestion, particularly, in this case, the versions that include a wifi adapter, the performance is overstated and VERY dependant on the electrical wiring. For example the 1000AV spec adaptors will really only achieve around 150Mb under good conditions. If the house (built in the 50/60s) hasn't been rewired then the performance could be badly impaired, and if it has been rewired with multiple separate circuits (and RCDs) then performance could be as low as 25Mb.
@w0036471 what speed FTTP product do you have ? and what sort of speed are you needing in your son's bedroom ?
w0036471
So, we're on Full Fibre 145 (so "up to" 145Mb down). All he'd be doing in his room is either playing Minecraft or watching Netflix on his phone, or casting Neftflix to his TV, so in and of itself nothing majorly draining. How would I tell what the wiring situation is by looking at my fuse box?
Fixes: 585
I would hope that it isn't actually a fuse box in the literal term, in that it has circuit breakers rather than actual fuses!
The circuits breakers should be labelled , are the upstairs sockets on a different circuit to the downstairs ? and is there more than one RCD ?
lahbrannan1
Fixes: 4
Hi @w0036471
There are a range of options available to you to boost the WIFI signal in your premises. You can explore WIFI extenders, internet boosters, a mesh system or powerline adapters. Which option you opt for is entirely prefential nevertheless all do have the same purpose with a few caveats. For example a powerline adapter which comes with ethernet ports allows you to transmit the signal from the main router where the primary plug is installed to the secondary plug (a different part of the premises) If you opt for the powerline adapter with the ethernet ports then you can always hardwire your connection to the secondary socket.
There are many different brands retailed however one I personally recommened is TP Link.
I hope the above is of some use to you though if you do have any further questions then please do not hesitate to reach out
Lee Brannan
