will th bt halo discs work with the hub2?
ricflairandy
Just signed up for plusnet so i beleive i will be getting the hub2 , i currently use whole home wifi mesh but would much prefer the lack of requiring a disc right next to my router. Will the halo discs work with the hub 2 does anyone know?Huh
3 REPLIES 3
Fixes: 480
Re: will th bt halo discs work with the hub2?
@ricflairandy  Welcome to the forum.
Your current system will work fine. However the Halo discs will not work with a Plusnet Hub 2.
If you also have the Halo compatible Smarthub then that can be configured to work on a Plusnet service. You will find the settings and other information pinned to the top of this board.
ricflairandy
Thanks. So i could basically configure the bt hub 2 to work with plusnet?
Fixes: 480
@ricflairandy
Yes, See here and associated links  https://community.plus.net/t5/My-Router/Using-A-BT-Smarthub-An-Update/m-p/1795292#M24601
