usb1 on pnhub1
aghayevi
usb1 on pnhub1
Hi guys,
I found it very useful that plusnet router has usb port and i have connected my usb based docking station to the router and use it directly over the network. However, i have doubts about security.
My main question is: Can any other plusnet user access files on my docking station when it's up and running and connected to adsl router's usb port ?
Is there any actions i can take to protect files and folders ?
6 REPLIES 6
Fixes: 1,495
Re: usb1 on pnhub1
Moderators Note
This topic has been moved from ADSL Broadband to My Router
Fixes: 1,495
Re: usb1 on pnhub1
Only devices on your local network can see the usb device.
aghayevi
Re: usb1 on pnhub1
So, do i understand rightly that any request from other of local network won't get in and be dropped by your firewall, etc. ?
Btw, is it possible to password protect files over usb share ?
Fixes: 1,495
Re: usb1 on pnhub1
More or less, yes. If you leave the hub with the default settings it won’t be visible to the outside world.
Password protection/ encryption depends on various factors.
aghayevi
Re: usb1 on pnhub1
But i wonder is it possible to protect folder by password while it conntected to usb port in adsl router and how-to do it ?
Fixes: 480
Re: usb1 on pnhub1
@aghayevi
Be aware that the USB port on a Hub One uses the SMB1 protocol, see https://techcommunity.microsoft.com/t5/storage-at-microsoft/stop-using-smb1/ba-p/425858
