update me
richierich007
update me
hi PN hope you can help, i`m keep getting to have to reboot my router a few times a week, for the software version not sure if this is the latest version "Plusnet Hub One | Software version 4.7.5.1.83.8.263 | Last updated Unknown" on my 192 homepage
not sure if thats part of the issue? anyway thanks for the service been great apart from that, keep it up
2 REPLIES 2
Fixes: 378
Re: update me
@richierich007 I would post the update request in this topic:https://community.plus.net/t5/My-Router/Hub-One-5GHz-WiFi-issue/m-p/1696363#M15510 , although your issue doesn't appear to be one this update fixes.
bobpullen
Fixes: 330
Re: update me
@richierich007 - I've pushed the latest update to your router. You'll need to reboot to apply it.
