smart hub 2
mike360
smart hub 2
Hi all does anyone know if the smart hub 2 will work on PlusNet FTTP i know its works on vdsl mode also i know plusnet uses the same model but different colour i just want to save on p&p if i can. Thanks
9 REPLIES 9
Fixes: 387
Re: smart hub 2
@mike360 It does - you just have to change the username/password. Details pinned to the top of the 'My Router' board. Unless you are using it already on a PN service, in which case, no change is required.
mike360
Re: smart hub 2
thank you so much
Fixes: 387
Re: smart hub 2
No problem.
bobpullen
Fixes: 331
Re: smart hub 2
It will *if* it's either an FTTP model, or on a fairly recent firmware (where there is a toggle in the firmware to switch it between FTTC/P modes).
Originally it came in two flavours, one with all four ports designated as LAN ports and another with the fourth LAN port converted to a WAN port (same as the Plusnet Hub Two).
I think there may be some knocking about that are FTTC configured and still on an older firmware that doesn't have the toggle. If so, that could cause you problems.
Fixes: 387
Re: smart hub 2
Thanks, @bobpullen  - wasn't aware of that. Will bear it in mind.
mike360
Re: smart hub 2
ive got the one with wan port is that going be a problem iv already order fttp without a router iv only just seen the messages
Fixes: 387
Re: smart hub 2
@mike360 you should be OK - but I'll let @bobpullen confirm.
bobpullen
Fixes: 331
Re: smart hub 2
Should be fine then 👍
Fixes: 1,495
Re: smart hub 2
Moderators Note
This topic has been moved from Full Fibre to My Router
