Plusnet Hub 2 Router Light
caravanj
I suppose in the grand scheme of things my query isn't too important but I've just renewed my contract with Plusnet again & I opted for the new Hub Two router.
I installed it in a matter of minutes, changed the SSID & WiFi password to match the old router & all the smart devices found it immediately so everything's ok, it couldn't have been easier.
However, I assumed the circular indicator light would be illuminated all the way round at a similar brightness to the Hub One strip bar light, but mine is only illuminated, quite faintly, at the very top & very bottom.
I have checked the light setting & it is set to 100%.
2 REPLIES 2
Fixes: 480
Re: Plusnet Hub 2 Router Light
@caravanj
Only showing at the top and bottom is how it’s designed to look.
caravanj
Thanks for that, the reason I queried it was because it shows as on all the way round on the help video that I'd watched, but only because I like Heather. Lol.
