settings
- My Router
- settings
settings
15-05-2020 10:16 AM
i am about to replace my router could you help with setting please.
for fibre broadband settings it says
use "The password you use to log in to the "Member Centre"
" Member Centre" login has 10 digits
at the minute present broadband starred out password has only 8 stars.
are they different ? how can i disclose the 8 digit starred out password ?
cheers
Re: settings
15-05-2020 12:35 PM
@djm Welcome to the forum. 🙂
Just enter your password and it should be fine.
Starred out passwords don't necessarily correspond to the number of characters.
ADSL2+ Billion 8800NL
Re: settings
15-05-2020 1:22 PM
ok was just a bit puzzled by the amount of digits
thanks very much
Re: settings
15-05-2020 3:44 PM
