Cross on wifi symbol
- My Router
- Cross on wifi symbol
14-05-2020 10:49 AM
Thanks Lisa
Re: Cross on wifi symbol
14-05-2020 2:47 PM
Hi @ Lisamarie419519,
Thank you for taking your time to get in touch.
I am very sorry that you are having a problem with our service. I would advise you to change the SSID on the router so the device will register it as a new Wi-Fi network.
Firstly please can you open a device that can connect to the internet via a web browser and open the web browser (for example Google Chrome, Internet Explorer, Fire Fox, Edge or Safari). Next locate the address bar (where you usually type in www. Etc) and type in 192.168.1.254 and press enter on the keyboard. This should bring up the router setup page where you can find multiple tabs along the top. Please select the advanced settings option. This will then ask you for an admin password which can be found on the little card provided or on the router its self (it may also be referred to as the router password and will be case sensitive), after typing this in please press ok followed by continue to advanced settings. This will then provide you with multiple options with a second layer of tabs. The first option will say wireless please can you click on that. Underneath will have a 2.4 GHz option, a 5 GHz option and WPS please can you select the 2.4 option. This will next bring up multiple options below and one of these will say SSiD. Please change this and click apply.
Another option which may assist a better wireless signal is to separate the networks on your router so you can have a 2.4GHz and a 5GHz network running simultaneously. To do this you need to go back to advanced settings as above and click on the wireless option on the second layer of tabs. Next click on the 5GHz option next to 2.4GHz wireless. Under here it has an option to sync with 2.4GHz, please can you change this to no. Next there it says Wireless SSID, these needs to be changed from the original one so you can see that this is the 5GHz network, this may be easier to just apply (5GHz) to the end. Next press apply at the bottom followed by I am sure once it asks you. This 5GHz network is recommended to be used closer to the router and use the original network when further away. Unfortunately not every device will be compatible with this network but the wireless will still improve from making these changes.
Kind regards,
Josh
15-05-2020 11:26 PM
This topic has been moved from ADSL Broadband to My Router.
Customer and Forum Moderator. Windows 10 Firefox 86.0 (64-bit)
