port forwarding does not open certain port
mustywalji
3 ports in port forwarding rules
88 & 8095 are open
but 8090 is closed
what am I doing wrong
11 REPLIES 11
Re: port forwarding does not open certain port
@mustywalji welcome to the community
Looking at the rules you have created I see no issues, what is telling you port 8090 is closed?
If you check the hubs event log found in >Advanced settings >Technical Log >Event Log > Select category FWRL
you can see if the rule is working, the target device does not need to be switched on for the rule to work
example log entry
08:02:28, 22 Oct. FWL Port Forward Server(192.168.10.201) TCP 8090 accepted a new connection from 198.199.98.246
Can you connect to the device locally on port 8090?
@mustywalji
I'll admit that I don't know much about Port Forwarding, though I have set it up myself for Transmission BitTorrent on our home server.
Looking at your screenshot, the thing that jumps out to me is that the device that is trying to use port 8090 is labelled as "unknown", followed by what I assume is its MAC address, in the second column.
It is probably irrelevant, but have you tried giving that device a name and seeing if there is any change?
@Anonymous
From what I can make out, if the router does not recognise a MAC address it will make the device name "unknown-<MAC address>"
I always edit the name to match the device.
Randomised MAC addresses of a smart phone is a good example of this
EDIT: IP addresses can be used as an alternative to device name, for this the device needs a fixed IP Address should be used.
pjmarsh
Fixes: 24
@mustywalji , a couple of queries/comments on that,
  1. How do you know which ports are open and which are closed?
  2. The port would normally only show open if there is something listening on that port on the device that it is being forwarded to.  Something to try and work out is if it is not being forwarded, if it's being forwarded but to the wrong device, or if it's the right device but that isn't listening on that port.
@pjmarsh
The problem here is the Hub two will report the firewall has worked even though the port forward test has failed
Using https://www.yougetsignal.com/tools/open-ports/
So a local test on port 8090 needs to be verified
EDIT: if the port forward messages are not been seen the event log, this would suggest something external is preventing traffic on that port, maybe the Broadband Firewall found in members centre is set to High
https://www.plus.net/member-centre/broadband/firewall
@Dan_the_Van
"I always edit the name to match the device."
So do I - I don't like having "unknown" devices on my network!
mustywalji
the port 8090 is closed when I check port on 'canyouseeme.org'
I can connect to the device locally on port 8090
Your uploaded screen shot shows the port forward run working, what exactly is the device the rule is for?
Is there an app being used or something else?
I'm wondering if a different port can be configured
Further to my previous post, what method have you used  for the devices IP Address, DHCP or manual?
For manual in the IP Address settings have you set the default gateway and DNS fields? With no default gateway set there would be no route to outside networks
mustywalji
Hi Dan
the rule is for a cctv camera and DHCP is on
mustywalji
Hi  Dan
I changed the port from 8090 to 8065 and now the port is OPEN
thank you for your help
