What is this dos udp loopback is my neighbour hacking me
Unknow5833
Gived my neighbour my wifi password months ago and kept getting dos spoofing dos loop back etc what is this? i switched to plusnet and it's still happening i was with BT before she doesn't have my new wifi details recent one showed up with my device ip dos(UDP loopback) which included my device ip what is going on help please
13 REPLIES 13
Re: What is this dos udp loopback is my neighbour hacking me
@Unknow5833 welcome to the forum
You've redacted the source IP address so we can't tell who it is but; I see these messages a lot, there should be nothing to worry about
Unknow5833
Here.do u know where it says DST well i changed my device ip which is my fone then it came up dos UDP port loopback which it says in the pic but where the DST is DST= it came up with my device ip address how is that possible?
These DOS attacks are from all over, one of my messages has src=14.136.23.194 I see the same one in your extract
Most of the DST addresses appear to be 51.9.183.124 which is your broadband IP Address not your device IP Address.
A reboot of the hub may result in a new broadband IP Address, have you rebooted the hub?
Which IP do you think is your devices?
Unknow5833
Here's the one with my ip which is my device i find that strange yes i have reset it many of times and keep getting attacks it's only happened since i gave my neighbour my wifi pw but changed to plusnet and got a new router still getting attacks it's very weird to me
Fixes: 387
That IP looks strange for a Plusnet Hub, or am I missing something obvious, @Dan_the_Van ?
The default IP Address range for a Hub two is 192.168.1.64 to .254
I know 172.16.108.24 is a private IP Address but I have seen plusnet using them.
Unknow5833
Yeah your correct i was getting attacks so i changed the plusnet hub ip because bt and plusnet use the same ip which my neighbour had,i believe she has something to do with it so am i overthinking?
Fixes: 387
OK @Dan_the_Van , thanks.
You are over thinking this, everyone just see's your Public IP Address (broadband IP) not the individual device IP.
I see these DOS attack  messages regularly, here are the last four
02:00:01, 23 Oct.
DoS(Port Scanning): IN=ppp1 OUT= MAC= src=14.136.23.194 DST=80.299.xxx.xxx LEN=60 TOS=0x00 PREC=0x00 TTL=48 ID=42965 DF PROTO=TCP SPT=25951 DPT=22867 WINDOW=0 RES=0x00 URG ACK PSH RST SYN FIN URGP=35330 MARK=0x8000000
02:00:01, 23 Oct.
DoS(Spoofing): IN=ppp1 OUT= MAC= src=14.136.23.194 DST=80.299.xxx.xxx LEN=60 TOS=0x00 PREC=0x00 TTL=48 ID=42965 DF PROTO=TCP SPT=25951 DPT=22867 WINDOW=0 RES=0x00 URG ACK PSH RST SYN FIN URGP=35330 MARK=0x8000000
02:00:01, 23 Oct.
17:58:16, 22 Oct.
DoS(UDP Loopback): IN=ppp1 OUT= MAC= src=147.185.132.27 DST=80.299.xxx.xxx LEN=68 TOS=0x00 PREC=0x00 TTL=13 ID=0 DF PROTO=UDP SPT=17093 DPT=19 LEN=48 MARK=0x8000000
 I have redacted my IP Address, your last router might not have reported the messages, but the attacks would have still be occurring
Unknow5833
I literally gave her the hub manager details by mistake when i sent her wifi pw,i can't even hide my ssid doesn't let me just all seems weird to me i can't figure it out
Unknow5833
@Dan_the_Van @Ok thanks just new to this stuff thought she was attacking me or something
@Unknow5833
If your are worried, change the admin password to something of your choice >Advanced settings >System, if you really don't want her using your wireless change the name and password >Advanced Settings >Wireless
Unknow5833
@Dan_the_Van  thanks ill do that
