pnhub1 shared
Quiller
pnhub1 shared
I recently got fibre with a Plusnet Hub1 router.
I have a Mac and in Finder I notice that in the left hand column under "shared" is pnhub1. However, when I click on that I get a message "Connection Failed". I tried the "Connect As" button and connecting as a Registered User entered my name and password, but that also failed. (BTW is the password suposed to be my Mac password or my Plusnet password? -I've tried both). I also tried connecting as a Guest and that also failed.
The fibre connection to the internet and the router appear to be working ok, so what is the point of connecting to the shared device pnhub1 anyway?
3 REPLIES 3
Browni
Aspiring Hero
Fixes: 59
Re: pnhub1 shared
The USB connection on the Hub One is for a USB drive.
Quiller
Re: pnhub1 shared
Thanks. I put a USB drive in the back of the router and then clicked on the shared device pnhub1 and it connected to it and I could access the data in the USB drive. It does raise the question however of why not just stick the USB drive in the back of the computer?
jaread83
Fixes: 81
Re: pnhub1 shared
I have a 2TB USB drive connected to my HubOne and all devices on my network can access it. Handy for when you want to share stuff between multiple computers without having to remove it and plug it into another machine.
