onehub security features
teal
I wonder if you could ask the firmware designers to add some more security functionality please?  In particular Im looking for:
1. Option to deny all wifi except whitelisted devices by mac address
2. Option to not transmit wifi SID
3. Option to deny router admin panel access via wifi (so wired ethernet only)
4. Hide Broadband username on router admin panel home page after connection login session
5. Password lock out for xx failed attempts (this might exist, not sure)
6. Login audit log
Id be grateful if you could check to see if the hub one has ftp, telnet, etc disabled.  And admin panel by https only (depricate http)
Thanks,
teal
edit, correct spelling
Tags (3)
7 REPLIES 7
Fixes: 419
Re: onehub security features
Whatever you do don’t hold your breath whilst waiting for a positive response.
teal
 Be patient then buddy.  Ive always found plusnet support very decent.
Moderator's note by Dick (Strat): Full quote of preceding post removed as per Forum rules.
Fixes: 1,484
Moderators Note
This topic has been moved from Fibre to My Router
Fixes: 419
I’m not disputing that but am not aware that it extends to rewriting router firmware to meet your exacting requirements.
ejs
Aspiring Hero
Fixes: 25
Attempting to hide the wifi SSID doesn't really add any extra security. It was not designed to be hidden, and even when "hidden", it still ends up being transmitted periodically. And then with it being "hidden", it causes other problems, devices that connect to the wifi have to keep transmitting the hidden SSID to search for the network, wherever they go.
teal
Thats true if someone is sniffing the initial client broadcast and handshake packets. So agreed, its not security against a determined targeted attack to obtain someones ssid.  But it makes the job a little harder as you cant login without the ssid.
But other than a determined targeted attack, it reduces the attack surface significantly against opportunistic attacks.
Somewhat like not putting valuables on display.
teal
Well, I installed openwrt and the router is doing fine now.  Closed all the security problems I listed above.
Perhaps the plusnet support guys if they see this might pass my op suggestions along to the firmware developers for those on stock.
