router
- My Router
- router
router
10-12-2018 7:51 PM - edited 10-12-2018 7:55 PM
hi can I use this router ( linksys WRT1900A) on plusnet
Re: router
10-12-2018 9:17 PM
The WRT1900ac is a router only so can only be used if you also have a separate modem to interface between your ADSL signal from the BT socket and this router. If you are not happy with the free Plusnet offering you would be better off getting a combined modem/router
Re: router
11-12-2018 4:26 PM
thank you for the info and you have saved me from making an expensive mistake ,many thanks
Re: router
11-12-2018 8:52 PM
Moderators Note
This topic has been moved from Fibre to My Router
