hub one no dmz
viperstorm
Interested
hub one no dmz
i have the new hub one and im trying to get teamspeak 3 server running i have port forward the right ports and even dmz my computer on the hub but its not letting any incoming connection any help would be great ( pulling my hair out over this )
2 REPLIES 2
mikelahey
Fixes: 12
Re: hub one no dmz
The Plusnet Hub One is basically a re-branded BT Home Hub 5A, there are quite a few anecdotal accounts on the internet of port forwarding being flaky on the Home Hub 5A.
viperstorm
Interested
Re: hub one no dmz
thank for the replay mikelahey i tryed all day to fix the problem but ended up putting the old box back on and hay presto i got a dmz and all is working fine i hope they sort it out.
pitty the new box is just a cost cutter but thanks for the info
