disable 'remote management' on a Plusnet Hub 2
outcast
Aspiring Champion
Fixes: 19
Re: disable 'remote management' on a Plusnet Hub 2
@philipk wrote:
The first lesson is to understand and evaluate all possible "risks" within a standard home broadband network ...
...  It's all for fun ... ..  I may as well get stuck in to this; it's fascinating.  Also, it has it's benefits 😊
Just for fun, have you tried doing a remote port scan on your home network to see what "risk" your connection reports to the world ?
You might be interested to run the Gibson Research ShieldsUP!
Click on this - https://www.grc.com/shieldsup
Click on [Proceed]
There are a few tools on that page for you to play with to test your setup
To do the port scan, click on [All Service Ports]  and let the test run to completion.
philipk
will do👍
