disable 'remote management' on a Plusnet Hub 2
philipk
Is it possible to disable 'remote management' on a Plusnet Hub 2?
Many thanks
pk
16 REPLIES 16
Fixes: 388
Re: disable 'remote management' on a Plusnet Hub 2
I doubt it - I don't use one - but why would you want to? That function is effectively the only way you get updates to the Hub, and AFAIK, that is all it allows.
Champnet
Fixes: 21
@jab1  Surely a request for an update check should originate from the modem/router. I don't use a Hub 2 but a connection attempt using my external IP address will show the Netgear box login screen. I agree with @philipk this shouldn't happen and I see it as a security risk..........
Fixes: 388
@Champnet I don't use any PN kit, but my understanding is that the 'remote management' designed to enable Hub updates - I could be wrong, and don't really want get into a long discussion -it is a bit off my payscale.
Fixes: 585
@Champnet you are correct, the update check does originate from the router , it uses TR-069 to contact the Plusnet servers.
There is no remote access to the router GUI on a Hub 2.
@philipk as above BUT it is possible for Plusnet to remotely access the router for diagnostics via the secure TR-069 facility. A connection is ONLY possible from the Plusnet TR-069 servers.
Champnet
Fixes: 21
@jab1  Nothing personal but just applying logic based on experience, I could be wrong.
Edit : Thanks for your comment @MisterW
philipk
Hi All,
Thanks for your input.🙂
MisterW:
<snip> . . . it is possible for Plusnet to remotely access the router for diagnostics via the secure TR-069 facility. A connection is ONLY possible from the Plusnet TR-069 servers . . . </snip>
Can I interpret, therefore, that a 'bad actor' could enjoy remote access to my router via the Plusnet TR-069 servers?  Feasible?
Many thanks
pk
Fixes: 585
I would have thought that access to the TR-069 servers is highly secure
@philipk
If this of concern to you might I suggest you purchase your own router where you will have full control rather than use a locked down device such as a Service Provider Hub.
Fixes: 388
Personally, I think this is panic over nothing - but each to their own, I suppose.
Protech
Seasoned Pro
Fixes: 8
@philipk
The potential security issues relating to TRS069 are well documented
https://en.wikipedia.org/wiki/TR-069#Security
However if the current best practice recommendations are implemented by Plusnet the risks of  "bad actor" access should be minimal. Plusnet ,of course, still have full management access to your router.
If this is still of concern to you, then the simplest way to avoid it is to get your own router, which will not be on Plusnet's management platform.
HTH
You can check out but you can never leave ( easily)
Fixes: 388
Anyone using a PN Hub fallen foul of these 'security issues'?
philipk
Thanks for the very helpful and varied perspectives; much obliged.
Re: "panic over nothing"
I am taking an inexpensive online course in the 'dark' web. The first lesson is to understand and evaluate all possible "risks" within a standard home broadband network, however remote.  It's all for fun, not business or employment, but since I'm retired and somewhat bored, I may as well get stuck in to this; it's fascinating.  Also, it has it's benefits 😊
Many thanks again, fellas.  You've been a great help
Fixes: 480
I suspect that you can add BT, EE and most other ISPs that supply a freebie router to the list.
Fixes: 388
Probably, @Baldrick1 . I've been using ISP supplied hubs/routers ever since I joined Plusnet.
