asus DSL-AC68U
mike360
asus DSL-AC68U
hi all so i recently bought an asus DSL-AC68U (second hand) and was wondering if these settings are correct (see Picture) router is on the latest Firmware Version:3.0.0.4.386_50117
thanks
4 REPLIES 4
Fixes: 480
Re: asus DSL-AC68U
@mike360
Two questions:
1. Why? There are members of this forum who will tell you that this is not a good modem/router.
2. Which service are you on, ADSL, FTTC or FTTP?
mike360
Re: asus DSL-AC68U
1. some of those forums are quite old and the firmware updates may have fixed the issues plus i needed a router with QOS as the bt smart hub 2 doesn't have it
2. I'm on FTTC
thanks
Browni
Aspiring Hero
Fixes: 61
Re: asus DSL-AC68U
 Firmware updates don't change the fact that the underlying chipset is poor.
See Kitz forum
mike360
Re: asus DSL-AC68U
what vdsl2 wifi router/modem would you recommend. thanks
