Router change not working
Selinaoi
I’ve recently changed to a tp link AXE75 5400 to try and get some range. I can’t seem to connect it to the internet.
I’ve set the hub 2 to bridge mode. I’ve connected an Ethernet cable from the lan port of hub2 to the wan port of the new router. The broadband cable is plugging to the hub2
I’ve set connection type to PPPoe, tried to login using @plusdsl.net and password. This hasn’t worked.
I’ve tried using the VLAN settings mode bridge. Nothing. Then tried using custom VLAN settings with 101 as the VLAN name and 802.1q tag enabled.
None of this has worked. Any advice would be appreciated!
13 REPLIES 13
Fixes: 480
Re: Router change not working
@Selinaoi
Can you set the VLAN to Off? This is handled by the Plusnet hub.  Are you using one of the three LAN ports on Plusnet  hub, NOT the one labelled WAN?
Selinaoi
I’ve tried both with VLAN enabled and with VLAN disabled. Neither have worked.
Yes, it’s in the LAN port on the hub and in the WAN port on the new router.
Fixes: 585
you need your accountname in front of the @plusdsl.net
Selinaoi
I did do this, I just left out my username in the post just in case
Are you using auto complete for the username or password, sometimes a space is added to the end of the word.
Are you using the TP-Link Tether app or via a browser?
Selinaoi
No it doesn’t autocomplete anything but that’s a good thought.
I’ve been mostly using the tether app. I’ve tried the browser too but it seems to be the exact same
Fixes: 585
Is the Hub 2 light showing pink ?
Selinaoi
Yes it is 🙂
Fixes: 585
That's good, confirms its connected in bridge mode. So it's looking like a problem in the router config, either the PPPoE or you've still got vlan active
Selinaoi
I think it is the router config but I’m not sure what.
I’ve tried setting it up from scratch with no VLAN but still no success.
PPPOE is definitely selected
Fixes: 585
and is the password the correct one ? can you login to the member centre successfully with the same password ?
Selinaoi
It’s definitely correct. I’ve even changed it as I read they can cause issues and still nothing has happened
Fixes: 585
Does the AXE75 have any log information that might be useful ?
edit: managed to find a user guide (albeit US, the UK site doesnt have one to download!)
It does have a log, Advanced > System > System Log
alos check that the unit is in router mode Advanced > System > Operation Mode ( i dont see why it wouldn't be but... )
