Xbox series x not connecting to network
Alistair12
Xbox tries to connect using multiple Ip addresses at the same time but router admin page shows it connected as static ip address which seems to change by itself. I've tried everything to fix this problem. Has anyone any ideas on a fix
5 REPLIES 5
outcast
Aspiring Champion
Fixes: 19
Re: Xbox series x not connecting to network
Is the router showing more than one IP address because the Xbox is connecting by ethernet AND WiFi ?
Alistair12
Xbox is connected by ethernet cable and is showing wired connection. Plusnet advisor sent list of ip addresses it was trying to use. The xbox itself kept flashing up different addresses. Router management page showed static ip address.
Fixes: 479
Moderator's note:
Thread moved from Full Fibre to My Router
Fixes: 1,495
what is the problem you're actually trying to address here?
Alistair12
Xbox shown as connected using wired connection but will not connect to network. Router management page shows ip address as static, but xbox tries to connect using multiple ip addresses. Sometimes static ip address will change. Will only connect if router is restarted. Has anyone had the same problem and know of any fix.
