Xbox One S wired connection with Plusnet Hub 2
cblower1980
Hi All,
I have just received a Plusnet Hub 2 as part of a new contract. All my wireless connections are fine, but when I try to use a wired connection on my Xbox One S it stays connected for a second then disconnects. Have rebooted both Xbox and router but it persists. On the Xbox settings it shows 'NAT type: Getting info... then connects and disconnects. Swapping back to the old hub seems to fix it. Any help is greatly appreciated.
2 REPLIES 2
bobpullen
Fixes: 331
Re: Xbox One S wired connection with Plusnet Hub 2
Did you ever get to the bottom of this @cblower1980?
cblower1980
No, to be fair I just left the old hub in place as a workaround.
