FTTP + Fritzbox 7530
mdh2
Hi All
I got FTTP today.  All works well with the Hub 2, but I'd rather use my FritzBox 7530.
However, I can't seem to get this to work.  I've tried various tutorials for configuring, but none of them are successful.
Has anybody successfully used the 7530 with Plusnet FTTP and if so, can you let me know where I might be going wrong please?
thanks
4 REPLIES 4
Fixes: 585
Re: FTTP + Fritzbox 7530
Have you tried this one https://en.avm.de/service/knowledge-base/dok/FRITZ-Box-7530/1167_Setting-up-the-FRITZ-Box-for-use-wi...
You should just need your PlusNet username ([email protected] ) & password. You should set VLAN ID to off as not needed for FTTP
Let us know if that helps
edit: just looked at the manual , seems to be covered on pages 38 & 66
Mustrum
Fixes: 81
deleted after reading @MisterW  link.
Fixes: 388
@Mustrum The 7530 is FTTP compatible - see @MisterW 's post above.
mdh2
Many thanks
I had seen that, but I was being dim and hadn't put @plusdsl.net after my username.
Simple fix and all working great
thanks for your help
