Xbox One S wired connection with Plusnet Hub 2
- My Router
- Re: Xbox One S wired connection with Plusnet Hub 2
06-08-2022 7:26 PM
Hi All,
I have just received a Plusnet Hub 2 as part of a new contract. All my wireless connections are fine, but when I try to use a wired connection on my Xbox One S it stays connected for a second then disconnects. Have rebooted both Xbox and router but it persists. On the Xbox settings it shows 'NAT type: Getting info... then connects and disconnects. Swapping back to the old hub seems to fix it. Any help is greatly appreciated.
Message 1 of 3
(1,266 Views)
2 REPLIES 2
19-08-2022 9:56 PM
Did you ever get to the bottom of this @cblower1980?
Message 2 of 3
(1,206 Views)
21-08-2022 10:17 AM
No, to be fair I just left the old hub in place as a workaround.
Message 3 of 3
(1,183 Views)
- My Router
