Wireless router in the wrong position
Agraul
Re: Wireless router in the wrong position
Yes of course
Is samnsung S22
pvmb
Champion
Fixes: 17
@Agraul wrote:
It's just a router I don't have a phone.
Yes, but what 'Broadband' service is now at the premises? Who came to put the router where it is?
Normally for the ordinary FTTC (non fibre) contract nobody needs to come to the house. The router is posted and where it is put is up to the people living there - plugged into a power point and the Openreach phone socket; though the cable for this is fairly short.
With full fibre there is a physical install, so someone has to attend, but the position the installed ONT is put is a compromise between where there is a power point and where the person at home would like it put. The router is then plugged into the ONT by an Ethernet cable and gets power from the power socket.
If it's a PN Hub 2 router there is quite a long power lead from the power unit and this allows a lot of freedom over where the router is placed. It's the connection between the router and the ONT (if there is one) which may leave them close together. However the Ethernet cable from the router to the ONT can, in effect, be as long as you like. Subject to convenience.
Agraul
I also have a connection in another part of the house. I had from Virgin Media and it was in a very good position
Tags (1)
pvmb
Champion
Fixes: 17
What is the router plugged into on the wall? An Openreach telephone socket or an ONT (a small, newly installed, box with lights on top)?
Agraul
a small, newly installed, box with lights on front
Fixes: 392
Right, so it is Full Fibre - I assume 3 green lights on the top?. You can reposition the router itself by using a longer Ethernet cable between the 'small box' and the router itself. It just needs a power socket.
Agraul
But I still have a box in the house where Virgin Media had connected Wireless Router can connect to that one and put the one from Plusnet He's in a much better position, not at the head, where my daughter sleeps.
Tags (1)
Fixes: 392
Sorry, the Virgin  'box'/connection is no good for Plusnet, it is a totally different infrastructure.
Agraul
I know I just gave an example.
He could have put it somewhere else better.
Tags (1)
Fixes: 392
He probably could, but I doubt Openreach will reposition the ONT . I  suggest you obtain a longer Ethernet cable, and move the router.
Agraul
Who do I need to talk to?
Fixes: 392
To achieve what?
Agraul
Come and see the problem again.
Agraul
Do you work for Plusnet?
Fixes: 392
No,I don't work for  Plusnet, I am merely a forum member who tries to help others.
