Wifi works on some devices, not others
nabullett
This is a problem with the wireless function on my Plusnet Hub One router.
In my house we use 3 x laptops, 4 x android phones, 1 x android tablet, 1 x Nintendo Switch, 1 x Xbox 360, 1 x Nintendo Wii.
All of these devices connect to the wifi and get fast fibre broadband, except for two of the laptops.
Starting a few months ago, the connection started to be internittent.
Sometimes they would not be connected, but if I kept clicking "connect" in the laptop's network settings, sometimes they would connect eventually.
For the last two or three weeks, they haven't connected at all.
The third laptop connects and works fine, as explained.
Today I took the two non-working laptops to someone else's house, who also has a Plusnet Hub One router.
Both devices connected to their wifi instantly and worked fine.
Any ideas?
6 REPLIES 6
Fixes: 480
Re: Wifi works on some devices, not others
@nabullett  Welcome to the forum.
Try splitting the 2.4 and 5GHz bands, see. https://community.plus.net/t5/My-Router/2-4ghz-and-or-5ghz-best-practice/m-p/1351966#M840
After doing this go back into your device wireless network setting and try each band in turn. Use the best.
SammyM
Fixes: 101
Hello @nabullett,
Thanks for getting in touch and we are sorry to hear it is due issues you are experiencing with your wireless.
Can you try the steps suggested by @Baldrick1 and let us know how you get on.
 Sammy M - Sheffield Team
nabullett
Thanks so much Baldrick1 - this worked!
I un-synced the 5Ghz and renamed it.
On the two non-working laptops, I can now see the 2.4 and 5.0GHz bands.
Tried the 5GHz first and it didn't work, but the 2.4GHz does for both laptops!
Interestingly, for the already-working laptop, I can't see the 5GHz band in the network settings.
Not sure why this became a problem, when both were working fine for over a year?
Thanks again!
NigeBoy
Fixes: 480
@nabullett
Great news that this has fixed your problem.
Whilst all wireless devices will have a 2.4GHz band, 5GHz is a more recent option not available on all devices. That could be why you are not seeing it on the one laptop.
OskarPapa
Fixes: 65
Thanks for confirming that you're now able to connect those devices @nabullett.
Please let us know if you need any further assistance - we're here from 07:30-22:00.
