Wifi phones won't always connect. Various error messages.
- My Router
- Re: Wifi phones won't always connect. Various erro...
- « Previous
- 1
- 2
- Next »
Re: Wifi phones won't always connect. Various error messages.
01-12-2018 11:55 AM
Hello @abmscopes,
Thanks for getting in touch and sorry to hear you are experiencing this problem. As it is just the two phones can you advise the following;
- Does the same happen on a different wireless network other than your Plusnet one?
- Have you tried changing the channel?, if so did this provide any help?
Message 16 of 17
(368 Views)
01-12-2018 9:37 PM
Hi. Thanks for picking up on this. Yes, to the channels question - sorry, I have mentioned a few times now that I've tried all channels and this has had no effect. I know you have to try the obvious first though, so thanks anyway.
However, your first point is the next thing I need to try. Hopefully tomorrow I'll be in another house where I can try their wifi. I'll report back. Thanks.
Message 17 of 17
(350 Views)
- « Previous
- 1
- 2
- Next »
- My Router
