Wifi calling challenges
AndyBarker
Hi all, new to this forum so thanks in advance for any help that may be provided.
I have an issue with wifi calling. My provider (Virgin) have enabled my account with wifi calling and I can see the option in my setting is 'ticked'. My new home has terrible mobile network reception and we have Plusnet broadband in place.
As soon as my phone is connected to the broadband my wifi calling option disappears and I am unable to use the facility (obviously the time when I need it). Any ideas of what the issue is? Is there something on the router I need to do
6 REPLIES 6
Fixes: 251
Re: Wifi calling challenges
Hi Andy,
A warm welcome to the forums.
No there is nothing your need to do.  The phone will select what works best for it - 3/4G or wifi calling.  I have wifi calling on my EE service over Plusnet's internet service.
This might be a phone issue.
Fixes: 480
@AndyBarker
Can you use the Internet on your phone with the phone mobile data switched Off but connected to your Plusnet hub?
Moderator’s Note
This topic has been moved from Broadband to My Router
AndyBarker
Hi, yes. No problems with internet connection. It's just that the wifi calling seems to stop working when connected to broadband,
Fixes: 480
@AndyBarker
So the phone is connecting to your hub. I assume that your phone is set to allow WiFi calling? As @Townman suggests, it could be a phone issue but also possibly a Virgin configuration error. I would take it up with them.
@AndyBarker
I've just tried this and it worked on my Pixel 7 Pro.
Put the phone in 'Aeroplane Mode' and then enable Wifi leaving Aeroplane mode enabled
Screen displayed a message about calls being made using Wifi calling
HTH ?
Edit: - I only see the Vodafone Wi-Fi Calling message when phone is locked
AndyBarker
Hi, well I never! That seems to have worked. Thanks for that. Only my wifes phone to sort now. Same issue so lets see what happens.
Thanks a million.
