port forwarding question
wwffan2
Good morning, please how can I check my router is set for port forwarding this is too seed using torrents.
in the router it shows the following, does this mean my port 42150 is open
5 REPLIES 5
Re: port forwarding question
@wwffan2
You can check a port forward rule is working using this site https://www.yougetsignal.com/tools/open-ports/
There is a requirement for the device to be ready for connections for this test to give a positive result.
But, if you look at the Technical Event Log you will see an incoming connections for that port, the message will look something like
12:13:55, 08 Jan. FWL Port Forward Server(192.168.10.86) TCP 42150 accepted a new connection from 198.199.98.246
wwffan2
thanks dan, does this mean my port is open
That would be the expected positive result of a working rule
HTH
Fixes: 1,495
yes.
wwffan2
thanks
