WiFi range
jenfadee77
WiFi range
Hi - just set up my Plusnet two hub. Speeds are great. However the range is nothing compared to my EE Hub. I can’t get a WiFi signal upstairs which is a huge problem as that’s where my office is! Any suggestions greatly appreciated
3 REPLIES 3
Fixes: 118
Re: WiFi range
@jenfadee77
Which product are your on SOGEA (FTTC) or Full Fibre?
Is there any possibility of running ethernet cable - even externally?
If EE haven't asked for their router back you may be able to use that if it's not locked (others will advise).
Fixes: 1,495
Re: WiFi range
Moderators Note
This topic has been moved from Broadband to My Router
spile
Re: WiFi range
@bmc wrote:
@jenfadee77
You could also reconfigure it as a wireless point to confirm that it’s better than the Plusnet router and with minimal disruption if you have to send it back - you just get another wireless point or a used EE router (or similar) to reconfigure again.
