WiFi range
- My Router
- Re: WiFi range
WiFi range
a month ago
Re: WiFi range
a month ago
Which product are your on SOGEA (FTTC) or Full Fibre?
Is there any possibility of running ethernet cable - even externally?
If EE haven't asked for their router back you may be able to use that if it's not locked (others will advise).
Re: WiFi range
a month ago
Moderators Note
This topic has been moved from Broadband to My Router
Re: WiFi range
a month ago - last edited a month ago
You could also reconfigure it as a wireless point to confirm that it’s better than the Plusnet router and with minimal disruption if you have to send it back - you just get another wireless point or a used EE router (or similar) to reconfigure again.
