Weak security WPA/WPA2 (TKIP) is not considered secure
phcleaning
Hi
On my iphone in the settings>wifi it says under the plusnet connection weak security. when I select it, it says - Weak security WPA/WPA2 (TKIP) is not considered secure. If this is your Wi-Fi network, configure the router to use WPA2(AES) or WPA3 security type.
Does anyone know how to do this or any advice about it?
We are on a fibre connection.
4 REPLIES 4
Fixes: 388
Re: Weak security WPA/WPA2 (TKIP) is not considered secure
Welcome to the forums, @phcleaning .
Speaking personally, I would ignore this - it is Apple being ultra-cautious and trying to protect itself from (mainly USA) customers blaming them if they get caught out/hacked through their own stupidity.
phcleaning
Ok Many thanks John
Fixes: 1,664
Thanks for your post @phcleaning and welcome to our Community Forums.
I'd also say there's nothing to worry about. Looks like this warning message has come about since iOS14 was released.
There was a bit of talk about it at the time Here.
198kHz
Fixes: 42
@phcleaning
Welcome to the forum.  🙂
Unless your router is really old, WPA2 (AES) should be an option, and should be used in preference to the weaker TKIP.
https://www.howtogeek.com/204697/wi-fi-security-should-you-use-wpa2-aes-wpa2-tkip-or-both/
BT technician (Retired)
