Warm Reset
- My Router
- Warm Reset
Warm Reset
22-10-2018 6:48 PM
Howdy,
Connection been stable as a rock, uptime of somethink like 15 days at 55mb and 2.5db-3db down, then yesterday it decided to "warm reset" itself, dropped 2mb while at it down to 53mb.
00:01:08, 01 Jan.
dsl:VDSL link Up: Down Rate=51936Kbps, Up Rate=7408Kbps, SNR Margin Down=6.10dB, SNR Margin Up=3.00dB
00:00:35, 01 Jan.
:The Modem has successfully powered up
00:00:35, 01 Jan.
:WDG Laststatus:: # Current boot was caused by Soft Reset (SAAF)
00:00:28, 01 Jan.
:The Modem underwent a warm reset
00:00:23, 01 Jan.
:WAN: ethernet as LAN
So my question is what is a warm reset and why did it do it?
Regards,
Feeps
Re: Warm Reset
23-10-2018 9:28 AM
Hi @feeps
Are you using the Plusnet supplier router or your own?
Your RADIUS logs don't seem to match up with the logs you have posted above;
If you are indeed using a 3rd party router - I'd hazard a guess that there was an update of some kind?
Thanks,
MoR
Re: Warm Reset
23-10-2018 9:47 AM
Hi @MasterOfReality, using the BT HH6. I thought that also, but the firmware and date are the same as before :
SG4B1000B540
24-Aug-2018
Does BT force router reboots after a set period of time then?
Regards,
Feeps
Re: Warm Reset
23-10-2018 11:42 AM - edited 23-10-2018 11:45 AM
Re: Warm Reset
24-10-2018 2:19 PM
thanks for the reply and answering my question at the same time
