Wan port query
Fixes: 144
Re: Wan port query
There should be one cable from the VR600 to the switch, the cable removed from the VR600 plugs into the switch.
Assuming you bought the switch recommended when a active cable is connected a green led should light top left of the socket.
HTH
cslogg
Re: Wan port query
Its working fine now.
No idea where I went wrong but  went back and removed the lead from the switch and put it back in the VR600.
I then took a different one from the V600 and stuck it in the switch.
When I move to Plusnet on Monday I will stick to my VR600 and see how it goes.
If I do then move to the Hub2 everything is in place to just mirror the setup .
