Fibre dropping out after 5 minutes
VYEATS
Hi I am new to Plusnet and fibre was dropping out every 5 mins then saying password was wrong! Have tried everything but disabling 5Ghz has worked-do I need this? Will it impact on my speed please?
16 REPLIES 16
Fixes: 480
Re: Fibre dropping out after 5 minutes
Moderator's note:
Topic moved from Broadband to My Router
Fixes: 587
@VYEATS if all your devices are only 2.4ghz compatible , then No. However 2.4ghz is limited to around 100Mb real world speed, so if you've got devices capable of using the 5ghz band then they will suffer the reduced speed.
This https://www.intel.com/content/www/us/en/products/docs/wireless/2-4-vs-5ghz.html gives a good explanation
Fixes: 392
Welcome to the forums, @VYEATS . What you have said above sounds very strange. If your connection was dropping out 'every 5 minutes' that suggests a network issue, Saying the password was wrong suggests your username/password combination was still set to <[email protected]>, rather than <[email protected]>, and disabling 5Ghz is a slight red herring - that will have no bearing at all.
VYEATS
Hi I checked that, it was definitely my username not setup@
Fixes: 392
What happens if you re-enable 5Ghz?
Fixes: 480
@jab1
My reading is that the network is up and fine as it works when devices are connected via the 2.4GHz band. The problem is therefore  the  rejection of the 5GHz SSID password, presumably an incorrect flag being raised by the synchronised 2.4 and 5GHz bands.
Fixes: 392
Thanks, @Baldrick1 . Hadn't thought of that, but AIUI, both bands use the same P/W?
VYEATS
I’m too scared to!
VYEATS
Ok I’ve turned the 5 g back on and downstairs devices still working but upstairs ones can’t connect to internet
Fixes: 392
Strange. What devices do you have upstairs, and how old are they?
VYEATS
Amazon fire stick old version and a HP pc 2 years old
Fixes: 392
What message do you get on the PC? I suspect the Firestick uses 2.4Ghz only. Did these items connect whilst the 5Ghz was turned off?
VYEATS
Yes they worked on 2.4
Fixes: 392
In that case, and providing you are on FTTC and not Full Fibre (FTTP), my suggestion is to turn the 5Ghz off.
