Vigor 130 with TP-Link Deco M5 Mesh
- My Router
- Re: Vigor 130 with TP-Link Deco M5 Mesh
30-12-2021 3:19 PM
Hello folks. I am have been running a Vigor 130 Modem with a four node TP-Link M5 Mesh system for a couple of years on an FTTC service. Downloads speeds are down to around 55-60Mb from the ~70Mb I had many moons ago (measured via SamKnows). With increased usage (4K streaming, consoles, virtual lessons) & permanently WFH I am now considering a WiFi 6 router which has prompted me to try & resolve performance. As I understand it PlusNet helpdesk will not discuss performance issues if not using their hub, so hoping the great & the good here can help
MTU is 1520 on the Vigor 130. For some reason I cannot access the modem GUI console directly unless I connect directly (but I think from reading around this is to be expected?)
Any suggestions would be very much appreciated - thank you!
30-12-2021 7:19 PM
Hiya @Quiffsrer68, thanks for getting in touch. I am sorry to hear that you are having some issues and noticed a speed drop.
Whilst our other forum users are the ones to best support you with your router/ modem queries, I have tested your line and can see you are currently banded, so have raised a request to have this lifted to see if this helps things for you. This is usually actioned within 3 working days.
I have raised a fault ticket here: https://www.plus.net/wizard/?p=view_question&id=220752645 just so our faults team can keep an eye on this for you.
I can also see there has been a few drops in connection, though was unsure if this was from you rebooting the router etc? I have provided the connection logs below for you to review:
30-12-2021 8:47 PM
Thanks @LaurenB . I can confirm the disconnects are as a result of my rebooting the modem & router a few times.
I will monitor speeds over the next few days. How will I know the banding has been removed, & do I need to do anything afterwards (reboot etc)?
31-12-2021 9:59 AM
Thanks for getting back to me and confirming, if that explains the drops then that's one less concern ![]()
You may just need to reboot once the line is banded, so maybe just give it a reboot by about next Tue/Wed if you haven't heard from our Faults team or feel free to give us a nudge on here and we can retest for you.
If you have any queries in the meantime though, just get back to us!
31-12-2021 2:02 PM - edited 31-12-2021 2:05 PM
Thanks again @LaurenB . I noticed the fault ticket shows a maximum download speed of 66.9Mbs which means there is potential to get another 17% from my actual 56Mbs.
For anyone else viewing this thread, I am still trying to understand what the optimal MTU set-up should be. Testing via http://www.letmecheck.it/mtu-test.php shows
The maximum MTU size for 212.159.23.132 is: 1480
It looks like the MTU on the Deco M5 router isn't configurable, so I guess the question is what should it be on the Vigor 130?
08-01-2022 6:46 PM - edited 08-01-2022 6:51 PM
On my Draytek 2762 modem router, I found an MTU of 1520 cause very random issues and setting it to 1492 resolved them all.... somehow I'd changed it when I did a firmware upgrade to the Draytek and it set itself to default 1520, certain sites would not load or would take forever to load.... lots of odd behaviour, I think someone on here suggested lowering MTU, my Draytek has an MTU detect feature in its web menu and it chose 1492 and was perfect after that.
09-01-2022 11:45 PM
- My Router
