- My Router
- Using the BT Smarthub 6 on a Plusnet Account
24-04-2020 7:27 PM
I've just read this with some intrest as do you know if i was to get a hub 6 what type do i need? A or B most on flea bay are type A, with a few type Bs about, I have unlimited fibre extra and wondered which would be the best to use?
many thanks
24-04-2020 9:27 PM
Hi
I think if you wade through this thread you will get much more seasoned information than mine from Baldrick et all. that said the main decision is whether to go for a business or home hub 6. The former allows you to set DNS servers statically (which might or might not be a relevant thing for you). I am currently running on a home hub 6 which works fine with plusnet. The only downside is that the BT public wifi is shown as enabled and can't be turned off. This is as of firmware SG4B1000E020. I can't find any evidence of this being an issue with losing bandwidth as I can't imagine it would reserve bandwidth, but it is a bit irritating. The part number of my home smart hub is 084316 - so that is known to work. I've just upgraded to unlimited extra, but it hasn't worked as yet as Openreach haven't done their thing yet. Hopefully in the next 24 hours. Once it's upgraded I will report back on the performance and then swap it out for a Business hub part number 088315 and I will report back on how that gets on.
Regards
25-04-2020 9:16 AM
I have the same issue re BT WiFi on my HH6, but have noticed a slight drop in speed since the overnight upgrade to SG4B1000E020. The speed drop may just be be coincidence from the ADSL reset.
I can't see any SSIDs for BT WiFi on my Laptop, or on the WiFi analyser App on my phone so assume that BT WiFI is not actually active.
25-04-2020 9:31 AM
I haven't spotted any with the same signal strength as my SSID so I'm also thinking / hoping it might not actually be active.
The increase in the attenuation figure is also mentioned on the BT users forum and some of them did see a speed reduction too - but I'm hoping it's just a GUI change as my speed went back to its previous level.
25-04-2020 9:52 AM
Best regards
25-04-2020 9:53 AM
25-04-2020 9:53 AM
There are only 2 WiFi AP's in range where I live, mine & next door's. Next door also have a HH6 that I installed a few weeks ago, I disabled BT WiFi on their HH6 and can't see any BT SSID from there either, I've not checked but am guessing their firmware is also updated. Perhaps the BT WiFi is only active if you have a BT account.
25-04-2020 9:56 AM
25-04-2020 10:04 AM
The WiFi signal on the HH6 is just about as good as any that I've seen, for the price of a used HH6, I doubt you'll get better value. The only downsides I've come across on the HH6 are that you can't set your own DNS and now the possible issue with BT WiFi. The Business Hub version lets you set your own DNS, not sure if it has the same WiFi issue tho.
25-04-2020 10:23 AM
One thing I don't understand - who's pushing these firmware updates, Plusnet or BT?
25-04-2020 10:32 AM
25-04-2020 10:35 AM
26-04-2020 11:38 AM
Have you any idea what might be happening?
26-04-2020 12:47 PM - edited 26-04-2020 1:06 PM
See my post 41 here
https://community.plus.net/t5/My-Router/BT-Home-Hub-6-Smart-Hub-on-PlusNet/td-p/1349153/page/3
and Poster Baldrick 1 post here (he uses a Business Hub which is same set up)
https://community.plus.net/t5/My-Router/Using-the-BT-Smarthub-6-on-a-Plusnet-Account/td-p/1587673
Are you connecting your BT Smart Hub for FTTC/ ADSL. or FTTP. ?
If FTTP then you will need a Special BT Smart Hub with the Red Port.
Only connect the DSL cable when you about to connect after entering your username@plusdsl.net and password.
At one stage the router would not accept odd characters in the password like %^&$£@:- etc so the password had to be changed before connecting.
make sure you are entering 192.168.1.254 into the address (not search) field of a browser. The 'Home' page will appear.
Only need to reset/Hard reset the router if buying 2nd Hand
ensure "Smart Set Up" Tab is switched off in router settings.
26-04-2020 2:12 PM
- My Router
