Witter
I will do thanks
Fixes: 480
@Witter
As suggested by @LifeonMars ,  after Openreach have done their stuff the account has ro be activated by Plusnet. This can take up until midnight. See whether it's working in the morning.
Witter
I will do.do I just leave the router as it is or reset it?
LifeonMars
Seasoned Pro
Fixes: 12
Leave it as it is as long as it has your usual passwords for plusnet  entered in the settings ie, [email protected] and the password you used to connect to plusnet. ensure Smart set up tab is off.
Fixes: 480
@Witter
Providing that your username and password have not changed then just leave it. If it's not working in the morning try switching it off using the Smarthub on/off switch on the back, leave it a minute then switch it back on.
mechanic123
- confused by eBay listing!
Amazon lists some Smarthub devices as 'locked' but the eBay listings don't seem to distinguish these. Are locked HH6 devices usable on PN or not? And how to tell if it's locked before laying out the cash? This is on a VDSL connection to PN.
LifeonMars
Seasoned Pro
Fixes: 12
Re BT Smart hubs
If you were to purchase one from a BT shop then it would presently work with plusnet and BT only.
bobpullen
Fixes: 330
@mechanic123, a highstreet-brought hub will be unlocked. Any device that has been acquired through a BT-contracted service will be locked to certain 'realms' (bit after the '@' in your broadband username).
Plusnet realms are permitted, so whatever the weather, I'd expect the device to work with Plusnet.
esoxecosse
I'm not using my Business Smart Hub if anyone would be interested in it, the model number is 088315, drop me an email on [email protected] if interested.
Cheers
MarkC
Witter
According to the tech team the router is broke and I'm already activated apparently when I'm clearly not and the router is not broke as I used it in my last house,could I get connected by factory resetting the router?
LifeonMars
Seasoned Pro
Fixes: 12
Try a complete reset, remember to keep the pin in the back of the router reset for at least 30seconds
however do not put the dsl lead into the phone socket until you have entered  the correct username and password.
being [email protected] and password.
previous passwords on a BT router did not accept strange characters like £$%^&*(£@ etc. But this may have changed with the new firmware.
Once entered, plug the dsl cable in and select the connect tab at top of the page
jwsg
Blaming the (known good) router was not a great bit of fault finding and if plusnet believe that they could easily  prove it by sending you a new Hub 1.
i would think the simplest explanations for not getting orange on the router are the likeliest - such as your new line not being properly connected to an active port in the fibre cabinet, but as you mentioned a recent socket change it would only take moments to plug the router into the test socket to eliminate the new socket too.
Witter
I'm all connected now through the test socket and I was told to just use that,hey said it was probably a faulty faceplate but I even bought another mk4 faceplate and that didn't work either
Fixes: 480
@Witter
Do you have any extension cabling connected to the faceplate?
Witter
@Baldrick1 the engineer just got me to replace the nte5 with a 5c master socket by puting 2 wires in but there's no wires connected to the faceplate
