atann
What cable does the business hub come with? I didn’t swap the old Sky Hub dsl cable out. I’m assuming they are both the same?
bobpullen
Fixes: 331
@Farnzie, unless something's changed recently, the Smarthub is still SMB1 regardless of firmware image.
Fixes: 480
@Farnzie
As @bobpullen  says, they are still on SMB1. I thought that the firmware had been updated as mine was workung with a memory stick. However having checked today I noted that SMB1 had been enabled. Switching it off killed the connection.
If the firmware hasn't updated just restart it by switching the router off, leave it a minute then back on. Your settings will not be lost and the reboot should kick it into life.
dan17
Does anyone experience the details for the Pnet broadband resetting themselves in the BT hub? It just happened to me and I had to redo them all over again.
Fixes: 480
@dan17
Perhaps a few more details?
If this happens whilst you are trying to set it up it's because you have the DSL cable plugged in whilst setting your Plusnet credentials. You need to switch off the Smarthub and remove the DSL cable before switching on and setting the Plusnet data. You THEN plug in the DSL cable.
dan17
I set it up a while ago and it was working correctly. Without any input from me, the details got reset this morning.
Fixes: 480
@dan17
Interesting. It's the first time that I've heard of this. It will be interesting to see if any more such reports start coming in, hopefully it will just be a one off glitch.
LifeonMars
Seasoned Pro
Fixes: 12
Did you ensure that Smart set up tab had been set off.
dan17
Yep, it was definitely off, and I factory reset it when I first got it
Farnzie
@Baldrick1  I tried switching off but its still on very old firmware number - SG4B1000E01E. It's only been connected just over 48 hours though so maybe it needs more time.
Works fine though.
dave501
Fixes: 6
@Baldrick1 not sure if this has already been discussed but it would seem that the A and B versions use different hardware.
The 6A uses Broadcom BCM63137 chipset whereas the 6B made by Arcadyan uses Lantiq PSB4395 chipset.
blu3andp1p
I've been using the Homehub 6 for a few days now and not had many issues (aside from my partner heat gunning the phone cable and temporarily taking us offline lol), both wireless channels work fine as well!
If you have any issues such as the connection dropping like myself (i.e. orange light on BT home hub 6 or the BT support phone number showing when connected to the router) then you might have to sign in to Plusnet through the routers settings page to reauthenticate your connection. Todo this
  • Sign into to the settings page of your the homehub by going to 192.168.1.25 in your browser (make sure you're on the same network as your router when doing this)
  • Then go to advanced settings > broadband > enter Plusnet details, your username being plusnet_username@plusdsl.net
  • Click connect
Farnzie
Had ours pluggeg in for 3 weeks but still no firmware update? We had a BT chap in at work today & he said it wont update on a plusnet connection as BT diallers would not try to dial in to it. Is this right?
He did say I could plug it in at work (BT line/account) and it should update on that connection.
LifeonMars
Seasoned Pro
Fixes: 12
Always updated when I was with plusnet. Had no problem. Perhaps there is no update for your model.
Farnzie
What is the latest firmware no for the hub 6?
