Using others modem/router
bogart99
Until a few weeks ago all was working fine using a Netgear DM200 modem and a Netgear Orbi RBR50 router.
The suddenly could not access internet. So swapped out modem for another of same model, still no internet.
So connected a Netgear R8000P router still the same.
So what I would ideally like is someone who has a Netgear modem router setup to tell me what the settings should be. Years
ago I took a screenshot of the settings but of course cannot find it now.
One main question do I answer yes or no to the question asked
Does your internet connection require a login?
If yes what do I put in for login details is it [email protected]  or just xxxxxxx ?
If no asks for account name but only says input if required.
Am very confused can only try so many combinations so an answer to the login or not is a good starting point
11 REPLIES 11
Fixes: 388
Re: Using others modem/router
@bogart99 Yes, your connection does require a login - [email protected] and your password.
Screenshots of the setup screens would help others to help you.
Fixes: 585
@bogart99
Does your internet connection require a login? Yes
If yes what do I put in for login details is it [email protected]  or just xxxxxxx ? its accountname suffixed by @plusdsl.net . Password is the one you use to access the member centre https://www.plus.net/member-centre/login
Fixes: 1,495
Moderators Note
This topic has been moved from Broadband to My Router
bogart99
Fixes: 388
@bogart99 That all looks OK to me - can you get a connection?
bogart99
No as evidenced by the 2 latest screenshots. What I do not get is even though is set to capture dynamic address from Plusnet it does not as shown by last screen shot having no details for IP port.Screenshot (62).pngScreenshot (63).png
Fixes: 388
You need @MisterW on this - he is more clued-up than me - but the 10.x.x.x.x IP address looks a little wrong to me.
Fixes: 585
The 10.x.x.x is only the LAN subnet, that's not a problem , its likely the default for the R8000P.
TBH I'm not familiar with either the DM200 or the R8000P but somewhere ther should be a VLAN ID of 101 set for FTTC to work. This is normally done by the modem (in this case the DM200) but I'm not sure where its set.
Fixes: 388
Cheers, @MisterW . Networking isn't my forte, just thought it may be related.
Mustrum
Fixes: 81
@bogart99  how have you set up your DM200?
This link may be of some help.
https://thomascoward.co.uk/networks/netgear-dm200-modem-bt-internet-asus-router-ac68u/
bogart99
Finally got there problem was  DM200. For some reason had set itself back to Modem and Router and not just a modem.
Unsure why as nothing was switched off between it working fine and problem occurring at least if happens again I kjnow where to begin looking. Networking will never get my head around it.
Thanks for the time and effort guys👍
