Using a Unifi USG with the Plusnet One Router
Fixes: 585
Re: Using a Unifi USG with the Plusnet One Router
Strange how the PlusNet router works fine..
@RobK Some routers cope with the bufferbloat situation better than others. Basically what is happening is that acknowledgement packets ( going upstream ) to download data are being delayed due to lack of bandwidth on the upstream. Some routers are able to prioritorise ack packets over normal upstream data whilst others dont.
From this https://community.ui.com/questions/USG-QOS-and-Bufferbloat/3e6c79a0-9682-4c0b-9eef-58b23224e449 it seems like enabling and correctly configuring Qos for upstream & downstream rates on the USG might be able to alleviate the problem. It might be worth a try...
RobK
Thanks.
I've enabled Smart Queues on the WAN Port of the USG and using this website I have fine tuned it as close to max speed as possible without introducing Bufferbloat: http://www.dslreports.com/speedtest
Thanks for the tip, I'll monitor the speed for the next 48hrs.
RobK
3rd try to reply, why do my posts keep getting deleted...?Huh
Moderator's note by Dick (Strat): Posts released from Auto Spam Filter and duplicate removed.
Fixes: 585
Glad that seems to have improved things
