Using BT Router with Plusnet
- My Router
- Re: Using BT Router with Plusnet
yesterday
Ok, a bit of a mish mash here! I an EE broadband full fibre subscriber but have a BT SmartHub2 router from when I was with BT.
I guess EE saw what I had so didn't bother sending their own branded SmartHub. Anyway, it all carried on working from the BT/EE switchover without any input from me so I've had little reason to complain about this.
But - my next broadband provider could possibly be back to BT (so not a problem) or the Plusnet brand of the BT group, which is where I would appreciate advice.
Apparantly, using a BT SH2 for Plusnet is fairly widespread so I don't think I would be planning anything too challenging. All you need to do is change the username and password in the router hub manager, then plug in the ethernet cable. So, I thought I would try a "dry run". I managed to access the Hub Manager and found a Broadband Username and Password line which I imagine would be the bits I would need to change.
This is where I got stuck. There was no obvious way to actually change and then save new settings here. Nobody has flagged this as an issue on the Plusnet forums, so I am possibly doing something incorrect here. I have read the entire Baldrick thread on this topic to no avail - could somebody on here advise?
Needless to say, I could just plug and play if I used a supplied Plusnet router, but I'd rather not do that due to basic nature of the router.
Many thanks for reading this far!
yesterday
Be aware of the risks of using an almost 4 year old BT ISP supplied Hub / Router that
at any moment could be remotely updated with a new firmware that renders it useless.
8 hours ago - last edited 8 hours ago
Which basic nature of the router are you referring to?
To change the broadband username/password pair the Hub needs to be in a disconnected state, either click disconnect or remove the DSL/WAN cable.
Edit: the new username/password pair are saved automatically when the broadband connection is established.
7 hours ago
My posts relate to the original Smarthub, not the Smarthub 2. Over the production tun of these hubs there are several versions and of course, firmware updates. I have previously read of a failure to connect a SH2 to Plusnet. I have no idea if this was due to finger trouble / not following every step in the process or whether there is a version that won't play nicely.
7 hours ago
A thought could be that BT has now locked the broadband username/password to [email protected]/BT which is seen on the newer Hub supplied by BT and EE.
7 hours ago
I don't know. I am aware that the newer versions of EE and BT hubs are locked. That is less relevant since they are all now subject to a charge if not returned.
The attraction of the SH2 over the Plusnet Hub 2 is the fact that they are compatible with the BT mesh satellites. Otherwise as far as I am aware the Hub 2 has the same WiFi performance and additional bells and whistles, in my opinion, making it superior, apart from the colour..
46 minutes ago - last edited 45 minutes ago
Many thanks for all the kind people who responded - and to Baldrick for clarifying that his helpful guide only referred to the earlier Hubs.
I would be perfectly happy with the Plusnet router if it only had the ability to link to my black BT disc, but unfortunately the feature was omitted from that Hub. Abandoning my BT kit and installing a third party mesh system would avoid this and future problems, but it is quite an expensive option.
The user credentials section of my SmartHub2 do not have a box surround nor a drop down menu, to enable any change to be made to insert Plusnet credentials. I assume this is baked in, and there is no work around? I assume removing the ethernet connection would make no difference here?
Again, many thanks to all, and I welcome any further thoughts anyone might have!
20 minutes ago
You are trying to change the settings on the Advanced/Home page, accessible after entering the Admin password?
14 minutes ago
Yes.
- My Router
